Open loop only on plx
bender
I finished up installing my plx sm-afr tonight. I thought I had my stock chip patched for wide band when I had it reprogrammed. It is the upgraded stock program from hood tuned performance, I mostly did it for the egr but what I read was it was also for wide band among other things.
Anyhow, I replaced my stock o2 sensor with the wide band, then I installed the controller, but left out the nb wire. Followed the thread exactly then started the truck. I watched on datamaster as my temp rose and watched the afr's. The truck idled perfect, but stayed in open loop the entire time. Even after temps were above 140-150 it stayed open loop. So I shut it down and hooked the nb in to the ecm, and then restarted, it went closed loop as expected.
I have to have the nb hooked up to go closed loop. Does this mean that my stock chip is not patched for wide band. If so, it is not a big deal as my code 59 stuff is on the way, but was just wondering.
TYTILIDIE
METH HEAD
Re: Open loop only on plx
I would hang in there til you get your code59 stuff.:2cents:
WyoSyclone
Since you were running narrow band before the PLX install, your chip could not have been patched for narrowband, otherwise your AFRs would have been way off. With the narrowband now hooked up your ECM is still using that input and your PLX is just acting as a monitor. Once you go '59 it will all come together.
I'm running '59 but didn't hook my narrowband output, out of the PLX, into the ECM... when logging with DM my O2 mv's always stay at 444 (although my AFRs correctly show in DM) because the ECM is apparently still looking for that signal via the narrowband input..... I really need to get it hooked up because I keep throwing O2 DTCs without the NB connected.
bender
So I just drove it around town to see how it acted. I know the ecm cant see the wb data but I was under the assumption that dm could. here is a screen capture, I thought afr target would be my wb reading. It remains largely unchanged. I never got on it really hard, just drove easy. Is this what it should look like or is something not right.
WyoSyclone
You won't see the 'AFR target' info till you go to Code59, but you should see your O2 mv rising and falling since you have the NB tagged in to the NB wiring. Once again, your chip/tune doesn't have the WB patch, so your PLX, right now, will just monitor and show your AFRs.... HTH
cloneman315
It has been a while I need to look at my notes,I think that is why I did mine the way I did as I didnt have the patch.I inputed the wbo2 wire into the factory ecm and had tomake a conversion chart to convert voltage to a/f/.
