OK, just got my patched Ultimate back from Dig. Went for a test run and the truck goes from closed loop to open and back to closed virtually instantly. Now I think I know what may be happening but any thoughts would be appreciated.
I was driving without the ECM "installed." Just kinda hangin' there so I suspect a bad connection (an ECM connector not in all the way). Now that I know the truck runs and that DM logs wide-band I'll put everything away like it supposed to be. I got one good DM log and will get some more and then post 'em. First run looks maybe a bit rich, as in 10.1 AFR target. Truck felt strong though.
Big tip of the hat to Dig and Josh "Tooky" for putting up with all my questions.:tup:
Well making sure everything was plugged in and putting the ECM up where it belonged didn't make any difference. It's like someone is turning the key off and back on reeeeallllyy quick, because the tach tries to drop to -0- (but doesn't have time) when this happens.
Uh, may have it fixed. Reset fuses and all -seems- well. More testing tomorrow but a ride around the block (big block:rotf: ) didn't seem be an issue.
