ostrich + desktop pc....need an answer quick!!
supersports10
ok will this work?
ostrich + desktop pc + long usb cable ( 20 ft)
does the ostrich require a laptop to be connected, all the time???
i just installed my fifty pound injectors,
list of parts i have, g1 adapter, ostrich, 20 ft usb cable, stock memcal, tunerpro rt, datamaster.
my plan is to use the desktop to download a 50 pound tune from the ultimate, and get a baseline tune uploaded into the ostruch......
so my question is do you have to have a laptop connected to run the ostrich, once a tune is installed??:tup:
turbodig
Re: ostrich + desktop pc....need an answer quick!!
That'll work fine. It works fine without being plugged in to anything.
Semi-crazy idea for the laptop-challenged:
Go to Sams, and pick up a big inverter.
Load desktop PC into passenger seat. Power plugs in to inverter.
Bungee cords to tie monitor in place.
Log data.
Big and clumsy, but it works in a pinch...
supersports10
ok new question.... does the ribbon cable need to be plugged into the ecm, just to upload the bin file into the ostrich??
anotherwords.....open ostrich, set on desk, connect to pc, download 50lb bin, THEN take out to truck, and install??
Should work fine some of the real old ones needed ecm power but that issue was fixed.
supersports10
ok i have the ostrich plugged into the pc on my desk. how the hell do i get a bin file from my pc to tunerpro, and upload it to the ostrich??
Where'd ya find a 20' USB cable? Potential data loss? Don't know with USB if you can go that far.
However I do run my laptop (Datamaster) off an inverter in the cab. Works great. Eliminates any battery difficulties. Desktop in the cab? I guess no panic stops eh?
NecroWolf
lost marbles member
Log data.
:rotf: :rotf: :rotf: :rotf:
this is the best thing i've heard in awhile
turbodig
Ugly, but when ya gotta, ya gotta.
The small-form compaq/hps fit nice behind the seat. :)
turbodig
Thus the bungee cords. It's a no-brainer with a Ty, the whole thing can go in the back seat.
supersports10
ok dig...i am having a problem.... i found the ads, and xdf files off of code 59, but i am running the 58 code. i downloaded the stock motor 50 lb bin for the ultimate, from tooky's website.
problem is the truck stumbles, and falles on it's face unless you feather the throttle. i have tried like 6 different bins from the 50 lb setup.....no difference!
funny thing is it runs the same as when the stock injector ultimate was tried with the 50 lb injectors:oops:
i am currently running e-85 .
when the stock injector ultimate was used with the stock injectors, the truck ran great!:tup:
i double checked each time the bin was uploaded, and it verifyed each time.
i also unplugged the ostrich, then tried to start...no start......just to make sure the truck wasn't in limp home mode.
my injectors were from viscious v6?? used 50 lbers
but.....they all were scribed with 58.0 or 58.1 ?????
so should i use a 60 lb bin??
i just wish i could use the t3 24 stock injector bin, but change the injector size to 50 lb in the chip...is this possible??
so does anyone have a 50 lb, or a 60 lb bin that would be a great starting place??
