On WOT my VSS values drops off and on, almost 20mph. This is causing downshift and other crap. Anyone got any ideas ?
The green is the VSS and the blue is the gears, you can see in 3rd the vss drops which cause the gear dropped to 2nd.
This is the setup.
I called PCS, they told me to double check the voltage I have set for close and wot throttle. I checked that and it seem fine.
A better pic:
This is the setup.
A better pic:
