bender
The truck is running great, but I had a question about the pcv system. Someone in the past has deleted one of the pcv valves. On the drivers side is a K&N breather which I assume is correct, but from what I gather about the other side there should be a T with 2 pcv's one to the tb and one to the air intake crossover. Mine only has the one from the tb and its stuck in the valve cover. The port on the crossover tube is capped. Is this something I should put back to stock configuration?
