Can you run the PLX controller (wideband) with the Innovate DB gauge?
TYTILIDIE METH HEAD Jun 5, 2010 #1 Can you run the PLX controller (wideband) with the Innovate DB gauge?
turbodig Active member Jun 7, 2010 #3 Re: PLX with Innovate DB gauge Depends on what the innovate DB gauge expects for voltage. If it's programmable, then it shouldn't matter what the source is. If it wants/needs Innovate's serial connectoion, you're out of luck. Also it depends on which PLX wideband you're talking about.
TYTILIDIE METH HEAD Jun 7, 2010 #4 Re: PLX with Innovate DB gauge DB gauge uses a black wire called analog on the diagrams. So this would wire up to the LC1's brown wire (analog 2). I bought this PLX http://www.moates.net/product_info.php?cPath=48&products_id=163
turbodig Active member Jun 8, 2010 #5 Re: PLX with Innovate DB gauge TYTILIDIE said: DB gauge uses a black wire called analog on the diagrams. So this would wire up to the LC1's brown wire (analog 2). I bought this PLX http://www.moates.net/product_info.php?cPath=48&products_id=163 Click to expand... Can't program that PLX module that I'm aware of, so no, it won't work. The real problem is that Innovate makes you reprogram to use the gauge. I suspect this was done intentionally to prevent its use with other people's modules.
TYTILIDIE METH HEAD Jun 8, 2010 #6 Re: PLX with Innovate DB gauge Man that really sucks. I was hop[ing to use a red DB gauge. Oh well, I don't like the PLX gauge but I guess I'll have to live with it.
