popping at wot
Ryda85
Senior Member
my buddy has a ty that just had a tune up about 6-7 months ago...ran great....now in colder weather he can't go WOT because it sounds like it starts popping / backfiring. what would cause this? i told him to come sign up for the boards...maybe he will chime in
SY756
Re: popping at wot
If the cold weather is the only change maybe it's starting to run lean, causing the popping. Just want to make sure that it's not detonating if it is running lean.
turbodig
Re: popping at wot
Likely the overboost cutoff. Try taking 1 turn out of the WG rod.
Don't discount the ignition, either. I've seen "new" tuneups last less than 3 months.
Particularly if they installed whiz-bang wires or super-duper multi-terminal platinum plugs.
attackdog
Re: popping at wot
GM TURBO said:
I'd say overboost.
X3... or running lean like mentioned earlier. I had this problem a few days ago because I didn't have enough fuel in the tank. I filled the tank and got on it again with no problems. Make sure he has at least a half a tank of gas before getting on it in the cold weather.
-Dean
