Next Phase
Re: Project Executioner
Bump!
Bump!
Ordered new gauges. I went to the pull a part yard and picked up a 90's S10 gauge bezel that is open faced so I can use these gauges. I am going to have to make the cluster mount but after looking at it, it will be rather easy to do. I also picked up another headlight control panel so I can glass it in and smooth it out to use in place of the A/C control panel. Seeing I have the vintage air control panel I needed to clean up the space where the factory panel was. I will post after pics once its installed.
20160518_150508 by Will Robbins, on Flickr
Did you go with the Hydroboost setup due to the Whipple setup not creating enough vacuum?
Petraszewsky;n1650914 said:Re: Project Executioner
Excited to see what upgrades you're doing to the motor/trans...Is the 1500+hp in your sig with the 4.0 supercharger? I was wondering what you put down RWHP with the 2.9L.
