promgrammer question
BillC
Re: promgrammer question
edit (updated with VortecFiero's info) -- Use ctrl-C and ctrl-V. Don't use the copy and past menu choices, they only work for parameters.
vortecfiero
im creating a bin for my setup, changing max rpm etc
and of course I compare to a stock bin to check
to keep track of my changes Id like to be able cut and past the changes to the notes rather than key them in
vortecfiero
the CNTRL C and CNTRL V will cut and past the notes section
in mutiple bins with similiar changes, believe it or not , I was copying, opening a reply window to a post, pasting, reviewing, copying from the review and pasting to the notes !
BillC
Hmmm, whaddayaknow. It works! :eek: :D
Thanks for the info. One of the nice things about Java is you occasionally find little unexpected bonuses like this (the default behavior for a text field is to respond to the standard cut/copy/past key combos). When I get a chance, I'll see if I can tie in the menu choices to work for the notes, in addition to the parameters. But for now, just use those keyboard shortcuts if you want to copy/paste in the notes section.
