im creating a bin for my setup, changing max rpm etc
and of course I compare to a stock bin to check
to keep track of my changes Id like to be able cut and past the changes to the notes rather than key them in
the CNTRL C and CNTRL V will cut and past the notes section
in mutiple bins with similiar changes, believe it or not , I was copying, opening a reply window to a post, pasting, reviewing, copying from the review and pasting to the notes !
Thanks for the info. One of the nice things about Java is you occasionally find little unexpected bonuses like this (the default behavior for a text field is to respond to the standard cut/copy/past key combos). When I get a chance, I'll see if I can tie in the menu choices to work for the notes, in addition to the parameters. But for now, just use those keyboard shortcuts if you want to copy/paste in the notes section.
