Mick said:
Here are just a few examples :
Multiple file capability, open a "stock" version along with several versions of your modified code, etc.
Got it. In fact, that's been in Promgrammer for over five years, now.
Mick said:
Powerful comparison capabilities that allow direct visual display of differences found. Every wanted to know what they did to that expensive aftermarket chip to increase performance? Now you can find out with just a few mouse clicks.
Got that, too. Promgrammer compares all loaded bins and sends the results to a user-specified file. If you want it "visual", open the file in your preferred text editor -- no need to re-invent the wheel.
Mick said:
Search features that make it easy to locate an area of interest within the 513 different items of the $58 PCM definition.
Don't have search, but the main display is sortable by any column. Just double-click on the preferred table heading, and all values will be resorted. Makes it easy to find parameters by values or units, instead of just location or name.
Mick said:
Note: The $58 binary is relatively small as it is only 16KB. 32KB binaries typically have close to 1000 data areas defined, while OBDII binaries can have several times that amount.
Don't care. Promgrammer is 1227749-specific, as I stated earlier.
Mick said:
Full drag and drop functionality built in.
Have full copy-and-paste instead, including copying/pasting multiple parameters at a time. Depending on how you work, this is arguably more useful.
Mick said:
Based on the most popular and familiar interface in the world, the Windows GUI, so it does not require taking an entire instruction course just to use it.
You've been listening to Bill Gates a little too much if you actually believe everybody prefers to use windoze. But, Promgrammer works just fine in that operating system too, in all its various flavors.
Mick said:
A Notes entry for each item, each one capable of containing 1.2 gigs of text, typically used for documenting changes or even adding several rich text documents worth of extended information.
Used to have that. Based on user feedback, decided it wasn't really useful or needed. Changed it to have a notes section per bin. Size is limited only by the user's computer (RAM and hard disk size). BTW, if people would prefer to have both bin and parameter notes, it's easy to add back in (just let me know if that's what you want).
Mick said:
Graphical display of data in completely customizable 3D surface plots.
Only if you have Excel installed. If your users didn't get Excel free (like a bootleg or pre-installed on their computer), a lot of them may not be willing to spend the extra $$$ to activate this "feature".
Mick said:
Import and Export of table data in Excel spreadsheet format to take advantage of the many third party optimizers available.
Promgrammer can export in both text and CSV (a standard spreadsheet format) formats, both entire bins and user-selected parameters. Didn't see a need to import from a spreadsheet, since no ECM runs Excel files.
Mick said:
Promgrammer has a hex exporter. Once again, didn't see a need to reinvent the wheel and write a hex editor, since A) most prom burners include this capability, and B) there are a lot of really nice third-party hex editors out there if you don't like the one that came with your burner.
Mick said:
The ability to create a definition completely from scratch, with real time display of the binary data to make locating tables and other areas an easy task.
Direct import of Winbin format definition files, so there is wide range of applications already addressed in addition to highly accurate and complete PCM definition files that are currently available. (Most folks own more than one vehicle)
Don't need definition files and don't want 'em. As I've stated before, Promgrammer is 1227749 specific.
Of course, one point you left out is that using definition files makes it extraordinarily difficult to do the dynamic recalibration and recalculation that Promgrammer does. In fact, as far as I know, Promgrammer is the only editor available that automatically recalculates dependent parameters, performs code changes (the boost scaling) and automatically handles calibrations for
all available MAP sensors. And all without forcing my users to edit, or even use, an external definition file.
You should also point out that making a definition file, especially from scratch, is not easy. It is tedious, mistake-prone, trial-and-error work. And if you can't make your own file, you have to hope the guy who created the definition you're using actually knew what they were doing.
Fortunately, Promgrammer doesn't rely on any hacker-wanna-be guessing and hoping. It was developed using a genuine GM P4 parameter listing. No guessing, hoping or trial-and-error involved. So, unless you scam a copy of Promgrammer and use it to update your $58 definition file, that file won't ever be as good.
Mick said:
OBDII capable - the only software currently available that can even open and define a 512kb GM OBDII binary file.
Once again, don't care -- see above for explanation.
Mick said:
The built in live update utility means you will always have the latest version, and we are constantly adding enhacments and new features.
How "live" do updates need to be? All registered Promgrammer users get all updates sent
to them as soon as they are available. No waiting, no fuss, no requesting or checking, and no behind-the-scenes "Big Brother" nonsense.
Mick said:
Registration is easy, with a wide variety of payment options available We dont whine about which option you choose, even if it costs a bit for the transaction fees involved..
Registration for Promgrammer also easy -- just send money.
But, since I'm not doing this commercially, I can't take credit cards directly -- that's why I take paypal. Besides, if you don't care about transaction fees, why do you charge more for your program?
