Promgrammer?
TurboTPI
TPI Tuner
How do I get a bin to burn correctly onto my chip after I modify it using promgrammer? I was using tunercat and it worked fine. I got promgrammer just to see how it was and I like the way its setup, but when ever I try and burn a chip using it, I get an engine light. I am using PP2 to burn the chip. Thanks for any help.
93ty475
Re: Promgrammer?
here's a copy and paste from the chitownsyty.net chipping section...
0x0008 KKPGMID Program ID 0x58
This is the program ID, it identifies this software program (the code and all these tables are the software, you can run other software on our ECM). SyTy code is 0x58. Important note - our ECM does a check sum check. This goes through the entire table section, adds up the bytes, and the resulting sum (the check sum) is checked against the checksum value in the chip. If it is the same - OK, all is good, if it does NOT match, boom, sets a code, bad prom. Kind of like a parity check to make sure the data read is GOOD. Setting the Program ID to AA disables this check. All of my programs are set to AA, otherwise I'd have to re-calculate a checksum for each program I modify.
BillC
Re: Promgrammer?
Yup, either have to change the checksum or the Program ID. If you change the Program ID, like Servando posted, you won't ever have to worry about the checksum again (at least not until you change the ID back, which you don't ever need to do).
The other option is to update the checksum value. Promgrammer can calculate the checksum for you, it's under the Tools menu. Then, just enter that value into the checksum parameter.
The reason you didn't have a problem with Tunercat is that program automatically updates the checksum every time you make a change. Since BG and a few other well-respected tuners complained about that, I decided to make it a manual operation in Promgrammer. *** update coming that will make it easier to set the checksum, and an option to automatically update the checksum ***
skwayb
NWSTP
Re: Promgrammer?
In Promgrammer v1.1 you can have it calculate the checksum for you.The command is under the tools menu. After that just save the bin and then you are set.
BillC
Re: Promgrammer?
I should have a new version out tonight that will make setting the checksum easier.
