Re: Promgrammer?
here's a copy and paste from the chitownsyty.net chipping section...
0x0008 KKPGMID Program ID 0x58
This is the program ID, it identifies this software program (the code and all these tables are the software, you can run other software on our ECM). SyTy code is 0x58. Important note - our ECM does a check sum check. This goes through the entire table section, adds up the bytes, and the resulting sum (the check sum) is checked against the checksum value in the chip. If it is the same - OK, all is good, if it does NOT match, boom, sets a code, bad prom. Kind of like a parity check to make sure the data read is GOOD. Setting the Program ID to AA disables this check. All of my programs are set to AA, otherwise I'd have to re-calculate a checksum for each program I modify.
