Re: ProtoTy Project
Got a bit of an update, no pictures unless you want to see the meter I used. Wiring seems to be testing out, so far, for a test start. Unfortunately I have found that the fuel pump has sat too long and has decided that it no longer will run. I have received the fittings to plumb the oiling to the turbo and I have the piece to complete the oil cooler delete. Adding those items will close up the oiling systems. I need to make up some battery cables and locate the battery. Then all I need to get is oil, wires, cap and rotor then set timing and then, with any kind of luck, start her up!!!
I may be able to make my May 14th startup deadline. It sure hasn't been an easy journey so far, unfortunately it isn't over yet. Stay Tuned!!!
I do have a score for April!! I went to my Father-in-Law's shed to look for a gas can and what do I see there?!?!?!? A complete fan assembly for a 95 Intrepid!!! The fan assembly that I have been watching the junkyards for. It had a tag on it from a local yard that said " Both fans tested good". F-I-L no longer has an Intrepid so I borrowed them
