Question About Non SyTy Radiators
Rob Pod
I wanted to know, are they any different upper Rad
hoses that would work with using a Non SyTy Rad??
Since SyTys have the 45* angle on upper radiator
outlet.. Im sure others have used different radiators..
Also, Since I don't have AC I wouldn't mind tucking
Radiator into the radiator support a little bitt deeper..
For lil more room between Turbo and the Radiator..
What Car/Size would be best for doin or fitting this??
Thanx,
Rob
Damian
Re: Question About Non SyTy Radiators
I have a C3 radiator that I was going to swap in since the heator core connection was right in the middle of my 4" inlet on my turbo. It is narrower, Ill have to take measurements again to see how much narrower. I think I can still use it and it would help out quite a bit to make more room but Id need to make new support brackets to hold it in place.
On my stock radiator, I ended up swapping the passenger side end tank with the same C3 radiator and it helped me fit in my Cobra 4" elbow, but I still had to trim the elbow down to get it to fit in. Problem is that it really kills my spool up on my GT37. I think the only way youll truly get more room is if you have a set of custom headers made to move the turbo back a bit.
If youre just looking for a different hose, just get one of those universal hoses.
Rob Pod
A corvette radiator, I run the same one. Look at www.v8s10.com.
C3 Style or C4 Style radiator?? I will prolly buy Alu Rad
Off Ebay once I find out what exact 1 fits inside there..
I have 1 for my Stroked N ProCharged Rustang
it is a no name radiator but cant beat it for the $..
New Aluminum Radiator, Dual Fans, and Shroud
