Question about tuning
ABTsportsline
Hi, I'm new.
Ok so I've been reading through the threads in this forum and all seem to be about tuning the SyTy's oneself, via altering air/fuel maps based on custom engine setups.
I come from the VW/Audi tuning world so admittedly I'm spoiled by the concept of just buying a "chip" from a vendor that does all this for you. You install the chip, and voila! You have more boost and horsepower.
I realize these are much newer cars than SyTy's, but I'm also seeing the word "chipped" in here. I am not seeing an explanation of what kind of chip, however, and I don't see any recommendations of specific vendors.
Am I correct in surmising that there is not such a modification for the SyTy (boost isn't controlled by the ECU I'm guessing as this is older technology)? So then my question is, is there a "package" a vendor sells or something along the lines that perhaps just includes bigger injectors, a chip with new maps, maybe a different wastegate spring or what have you? I didn't see anything in the FAQs about vendors and what is out there as far as performance tuning. I don't think I'm comfortable with my own knowledge to just start piecing together a system; willing to pay a company for their R&D for upgrades. I'm not looking to build a drag Ty and would never want to take it to a track - but a mild horsepower upgrade over stock would suffice.
If this has already been discussed here, feel free to just post the link; I did read quite a few of the threads here and didn't see it discussed? :tup:
powercat6
Re: Question about tuning
Back in the '90s Kenne Bell and Applied Technologies Research made packages like those, but ATR is now out of business and Kenne Bell stopped making their products because SyTys are now too old to market to.
Some of these products can be found, but most people here would tell you to stay away from Kenne Bell chips because they don't retard engine timing when engine knock occurs. Tuning it yourself rather than getting a chip is better because you can just modify the tune yourself and you can set the tune specifically for your truck.
turbodig
Well, the main problem is that things don't work that way in the SyTy world.
Our trucks are MAP-Speed/Density based. There's no meter to determine exactly how much air is coming in. All you know is pressure and RPM, and Temp. There could be literally unlimited combinations of flow density given the unknowns in VE, compressor and exhaust size, intake runner geometry, etc, etc. Boost is ECM controlled- you can make it produce however much you want.
There are some vehicles that tolerate it better than others. MAF-based systems measure incoming air density, so they can deliver a planned amount of fuel based on that measured density. What they don't (and can't) predict, is that the intake system can vastly affect how a MAF performs, and what it reads.
There were companies that sold "chips" back in the day- They're all either out of business now, or simply not selling chips anymore. (Nobody that I'm aware of is still selling an "off the shelf" chip.)
There are folks still doing custom chip work for people (Campbell/Nolan, most notably), but it's done as it should be - data files from your truck get sent to them, they send you a bin to try and send back more data, until the process is complete. This gets you a real "tune", specific for your truck- the right way to do things.
The automotive aftermarket for years has sold the myth that you can buy a box of parts, a reprogrammed ECU, or a downloadable program device and magic will happen. It doesn't work that way.
ABTsportsline
Hi, I'm new.
Excellent guys, thanks for all the information :tup:
I just gave that powertuneplus site a huge read and have learned a lot. I will focus 100% of my efforts on maintenance and replacing the OE stuff with more OE-quality/type stuff to keep it as good as new, rather than building a big-boost alky or high-octane setup. I don't want to run on high-octane gas as this would be a daily and it's not easy or cheap to do that. Looks like keeping it stock, but well-maintained, is in the cards. Would be a good idea to get that datalogger as well to keep better tabs on how she runs. :tup:
This page in particular was immensely helpful:
http://powertuneplus.com/syclone/howto_stock13s.shtm
That powertuneplus site should be in the sticky in this sub-forum - great resource! :)
