Quickstop [UK]
Combating adversyty.
Hi guys,
I have a quick question for those of you that have done engine builds before.
I am doing mine this year and am not going all out at the moment, just want reliability.
I have ordered pistons, rings, ARP studs, new mains, cometics and a few other bits and bobs and they are on their way from RPM I hope by now!
I am puting in the JE pro pistons with childs and albert rings and am just after a solid truck, but later I would like the option to upgrade a bit further.
Should I spend some money on the eagle rods now or leave them stock - all I am changing at present are the pistons.
How much will the stock crank and rods take before I start to need new bits?
If I do put the rods in but do nothing to the crank/mains apart from a polish, how much power could it take if I decided to up the power a bit later on?
Or should I save my money for now, use the stock rods check them and start building a second engine for the real power - vortecs, 4 bolt mains, etc etc....
I am really not planning on going crazy for now but I am just a bit unsure - kinda feel like I should remove the stock rods while I am in there. I have a 20G and don't want more than 400hp off this build. Will the 20G even go to that?
Thanks,
Mark
Thanks,
Mark
