Removing fuel pressure regulator
SYO237
SyTy Registry
Re: Removing fuel pressure regulator
Go buy a new shrader valve. Bike shop, autozone, pep boys, etc should have them....hell, steal it from your neighbors or friends bike. Take off the sensor, put the valve back in and get the FP gauge from autozone to check it.
syty9933
what do i have to do to put in a new shrader valve, and how can i make sure mine is broken first? btw thanks for putting up with all these questions
SYO237
SyTy Registry
The valve screws in. You need the tool to get down in there and unscrew it out:
You should be able to get it as well at any bike shop, autozone, etc.
Not sure really how yours could be broken (the schrader valve). If you take the cap off the rail, it looks just like any air stem like you would see on tires.
syty9933
cool i have a puller, and i think i was trying to remove it for the sensor but didnt all the way. How can i tell if it needs to be repleced?
SYO237
SyTy Registry
the end of the removal tool slides over the valve down in the middle of the stem. Remove it like you would a screw or nut. Reverse to put back in, just dont crank it down with 180ftlbs of torque.
BoostedSUV
if the shrader valve is still in the rail you wont get a FP reading at the gauge. It has to be completely removed in order for the sending unit to "see" fuel pressure. if it is in fact removed and the sensor is bad (don't think its that common), you can get a replacement sensor for $99 from summit/jegs. Pretty much all elec full sweep 0-100psi gauges use the same sending unit. You sound unsure if the shrader valve is indeed removed??
Otherwise do as Adam is saying, get a shrader valve and a test gauge from autozone. Hell just take the shrader valve out of your Sy's tire.... lol you only need it set the fuel pressure! :lol:
SYO237
SyTy Registry
Is this a for real thread??? seriously????
The kid is 16, cut him some slack. He is doing the right thing by asking first, rather than screwing it up and costing himself more time and money.
I remember when I first started out that what I think are really simple things were foreign to me and had to ask someone...I still do on a lot of things, only way to learn.
13.robb
I just think with his knowledge level, maybe a stock truck may be a better idea. Maybe better to leave alone if you dont have a clue, or maybe buy some service books and start reading them. Thats all. I didnt know too much back then, but was never afraid to pick up a book and learn about it.
SYO237
SyTy Registry
I dont consider an AFPR that big of a mod..in fact, its a much needed mod even for a stock truck. Besides, no one reads books anymore, its all on the interwebs. :tup:
BTW, heres a pic of a removed scharder valve:
And the FP tester looks like this at autozone:
syty9933
im only 17 but ive done turbo swaps, helped build motors installed chips...etc., i probally could have done it without posting a thread but a cared enough about my truck to get it right , the reason i put one on is because my datamaster file showed im running a little bit lean. Ive seen alot more rediculous threads than this from people over double my age, and you have to learn somehow, i try to read up on everything i can from this site to further my knowledge ,ive done far more complicated things on my truck than a regulator, it was actually pretty easy i just needed some guidance to make sure. Thanks for the help
SYO237
SyTy Registry
I call my FL guys (even some of my Cali guys) with some stupid questions that I should know, but not sure if I am right. Nothing wrong with it...plus, its an excuse to see whats up and ask how things are going anyhow.
aasltmike
x2...I agree with ya. My father was building hot rods and learning about working on cars at age 10, then he joined the Army and was a mechanic there for 21 years. He retired from there and went to work for the US Post Office as a mechanic, going on 25 years there now and close to retiring from that. I learned about cars from him and I am now a mechanic in the Army and can hold my own in a garage, but I still ask the pro's on this site here about working on my Ty if I have a question. I would rather face ridicule from some tool that can't take it for what it is, a simple search for knowledge, than break it and face a more expensive fix after learning the hard way. Ease up and give the kid some slack.
syty9933
alright almost ready to go, so to adjust it with a pillar pod gauge i just turn it , take off the vaccum line on the regulator and adjust it, what is the method for adjusting it? do i keep it at idle or hold it at a certain rpm, and what should be the pressure for 14.7psi?
