Removing fuel pressure regulator
SYO237
SyTy Registry
Re: Removing fuel pressure regulator
Relieve the FP using the schrader valve on the rail (driver side). Then take off the 2 screws that hold on the FPR and install the new one. Careful to pay attention to the o-rings.
Have a towel handy to catch all the fuel that pours out the rail. Dont do it on a warm engine just for safety reasons of course.
syty9933
Thanks alot, and what do I use to take the 2. Screws off? Is it An Allen wrench
BoostedSUV
pretty sure it's an Allen socket screw holding the Reg to the rail and 5/8 flare nut that connects the return line to the Reg...
syty9933
im about to take the stock regulator off, and i already tookl the two allen wrench screws off. What do i do next. All i see is a hose by the fuel rail and a fuel line on the bottom of the regulator. What is next and how does it all connect to the fuel rail??
SYO237
SyTy Registry
The line on top of the regulator is just a vac line, you can remove it (just like you would when your checking base FP).
You should just be able to pop it off the rail now. There is an o-ring that seals the FPR. Just make sure that it doesnt get left behind in the rail and that the new one has it supplied, else you will have a serious fuel leak when the pump primes up.
If its the orig and never been off, just wiggle it and use light force to help it come off so you dont damage or bend the rail.
syty9933
aight cool all i have to do is take the fuel line off. For that is it just a flare wrench or what?
BoostedSUV
5/8 flare wrench...
Be carefull not to lose the o-ring on the fuel line.
SYO237
SyTy Registry
Hit it with some WD40 or penetrating lubricant and go do something else for awhile and come back to it.
BoostedSUV
thanks, i bought a set of flare wrenchs to be on the safe side too, but it wont budge. Any tips on getting it off??:dunno:
Its easier to get the fuel line off with the reg still bolted to the rail. I know my aftermarket reg has an area to put 3/4 wrench on to give you some leverage but I'm not sure about the stocker...
syty9933
yes the stock regulator has a 3/4 place for leverage. I tried that method and got it about half way, ill have to buy some bolt lubricant to get it off the rest
thanks
syty9933
ok its all together. What do i expect when i turn it on and dont know what the pressure is?Is it driveable?
SYO237
SyTy Registry
You really should get a FP gauge that screws onto the schrader valve on the rail to check it if you dont have a regular FP gauge hooked up all the time. You can buy them at autozone, something like $35, usually behind the counter. It has a bleeder valve on it.
Get the gauge, screw it on the rail (truck off). Since the rail is empty of fuel, just turn the key to the on position and let the pump prime up, then start the truck. From there, take the vac line off and adjust the FP accordingly with the gauge. When your done, turn the truck off, hit the bleeder valve on the gauge to relieve the pressure, unscrew it from the truck and jump back in and go get some kills to post up. :tup:
syty9933
my valve is bent for a fuel gauge but my sensor is dead :(, i do have datamaster if that works
syty9933
it wont tell fuel pressure?, i think i removed my shrader valve putting in a fuel pressure gauge for a pillar pod but my sensor for the gauge is broken. What are my options, only getting a new sensor?
