Replacement wastegate actuator?
MikeRenz
not stock
Re: Replacement wastegate actuator?
there are ones on ebay for $35-$100. Unless you're looking for OEM style.
Loeryder
www.hahnracecraft.com has all kinds of mitsubishi turbo stuff
Their site sucks to navigate since they changed designs.
Find the 20g "accessories"
They don't even have a SyTy section anymore. :tdown:
turbodig
And they don't have stuff for stock turbos, either.
Methinks someone should make up some brackets to mount the 2-bolt style actuators to the mitsi housing.... that'd be handy.
Loeryder
Yeah nevermind dealing with Hahn. I take it back.
I've been emailing with Brad at Hahn the last few days trying to get thread pitches for the 20G and other critical specs when building AN lines for oil and water.
He even called Mitsubishi direct and still couldn't answer my question.
So I told him to have one of his techs attempt to thread an oil feed fitting into the water ports.
If they matched then it would be a 14mm X 1.5 pitch adapter that I have been looking for.
Damn, I almost could have driven to Hahn and done it myself and gotten my answer faster.
The sales staff seems to careless about SyTy.
He says they don't sell enough of it to even justify advertising it on their new site.
Their new site design sucks ass btw.
It is all geared towards bolt on turbo kits, mostly sport compact crap.
Forget what I said about Hahn, they suck. lol
MikeRenz
not stock
working on it. Actually was trying to source an inexpensive actuator to make a nicer mount for the PTE turbos too instead of a bird poo frankenstein one it comes with.
If someone has an actuator they want to use and no means of mounting it....send me the shit and i'll make you a bracket.
George Blake
DONATING MEMBER
Quit talking in code, guys. Is there another actuator that I can just drill and tap the reclocking bracket to hold it?
MikeRenz
not stock
is your actuator messed up? overly rusty? broken? if you need to borrow a stock actuator i'll lend you mine
turbodig
MikeRenz said:
http://cgi.ebay.com/ebaymotors/New-...020QQitemZ300144073040QQrdZ1QQsspagenameZWDVW
this is a slightly cheaper one, and dual port - i assume you would just cap the port you aren't using and it'd work fine. Some boost controllers are push port, some a pull port....what're you using to control boost george?
Wouldn't cap it, just leave it open.
The 10 psi spring would be better.
That bolt pattern layout is semi-standard, so if you make up a bracket I bet it'll work for either.
You can do the same bracket for the 20g, overall dimensions are the same, but the holes are spaced closer together.
I have both here, I can fit-check for ya, get dimensions, etc.
If you can make 'em a bit thicker, or with bent ribs for reinforcement, it would help. High pressure springs might make it flex.
MikeRenz
not stock
i have a stock turbo and a 20g cover. If someone has an actuator they'd like a bracket for for either...send me the actuator.
I made the stock wastegate reclock brackets out of 1/8" alum, and it seems plenty rigid. Depending on the design of the bracket for a different actuator, 1/8" alum should be plenty strong also.
4C FED
Absolutum Dominium
When I tested my bracket in aluminum, it flexed to much.
