Rev Limiter?
dBaseD
I took my Sy out to moroso tonight for the first time since I got it and decided to make and datalog a few runs.
Best I ran was a 13.58@96 with a 1.90 60ft. Reason being that it seems like the truck literally lays down up top. As soon as I got over 4k RPM's the truck seemed to start a surging pattern. I took a look at the datalogs and - sure enough, it appears to do just that.
If someone can take a look at my bin and datalog and see if they see a reason why the truck is behaving like that I would apreciate it. The particular spot starts around sample 1365 and you can see where it seems just just bounce off 4500rpm and rev no higher. I hunted through all the tables and scalars in code59, I just didnt see anything resembling a limiter (that wasnt maked "NOT USED")
I apologize if this is a newbish post - I am new to tuning GM's in general though I tuned my Turbo 5.0 Mustang with both a Tweecer and a Megasquirt.
http://www.doomsday.org/Syclone/jason_syclone.bin
http://www.doomsday.org/Syclone/moroso3.csv
The truck has a PTE44 turbo, 50# injectors, KB A2A IC, and Old school KB300hsl converter, AEM wideband, an ostrich chip running code59, and a few other minor mods. No reason it shouldnt be going at least 105 in the 1/4 IMO.
Thanks
Jason
supersports10
Re: Rev Limiter?
what's wrong with this picture???
he has 9 posts,and has code 59, and i have over 1300 and been here since 04, and dont have code 59 yet.:oops:
hmmmm... time to get my butt in gear!!
dBaseD
Re: Rev Limiter?
supersports10 said:
stock rev limiter is 4500 i believe......
these trucks stop making power at 4500 anyways (stock)
Okie dokie, I just figured it would be 4800 since thats what the tach in the dash shows. It's too bad its 4500 though, as such the calclulator shows the best trap possible with stock tires size is 100, but with it bouncing between 4500 and 4300 i guess 97 is the best I can hope for at the moment. =)
EDIT: I was actually just looking at all the mods the previous owners did to this truck.. it has an oldschool grind cam in it as well. I dont see any reason this truck shouldnt be able to rev to 5k, considering it has exaust, a new downpipe, a turbo, a cam, and forged internals as well. Anyone have any idea where the soft rev limiter value is in the code59 xdf?
-Jason
Re: Rev Limiter?
You can adjust it and spin it faster but you will find our trucks like to be loaded aka shifted soon.
We pikced up significant et shifting early and loading the engine down and letting the torque pull you.
Peak torque is around 3600 for a stockish truck. Peak HP is ~3900 you want to shift at 110% of peak HP about.
Re: Rev Limiter?
Did you lock you torque converter on the run? It seems like you should have run 98/99 traps rather 96 mph. I still end up havin got shift OD, which you will probably need to do anyways with your combo.
You probably push a few more RPM out of it with a higher RPM ECM limiter. I agree with a PTE44, larger injectors, and a mild cam it will probably rev higher than 4500 rpm. I am too lazzy to log out my wife apple to tog into your runs. What RPM is your truck shit 1-2, 2-3? Is it bumping the limiter in those gears?
With you combo and more boost, your probably still going to have to Use OD. I would guess you should be able to hit 110mph in the traps with out going to crazy and prehap even higher depending on hard your push it. You will have to fix the rev limiter in the ECM and recalibrate the transmission govenor.
TYTILIDIE
METH HEAD
Re: Rev Limiter?
When my truck was stock and it over revved it didnt bounce it made a real shitty sound and shot out a big puff of smoke.
dBaseD
Re: Rev Limiter?
dgoodhue said:
Did you lock you torque converter on the run? It seems like you should have run 98/99 traps rather 96 mph. I still end up havin got shift OD, which you will probably need to do anyways with your combo..
Yeah, I had the converter switch set to lock. I checked the math, and with stock tire size and the Sy final gear ratio, 100mph is the theoretical highest trap in 3rd at 4500rpm. 97 is likely the result of the truck bouncing from 4300 to 4500 and back I would assume.
1-2 seemed to be about 4k and 2-3 seemed to be at about 4200. I didnt notice any issues shifting in those gears at all.
I tried shifting into OD my last couple of runs but the truck seemed uninterested in doing so. I was pushing it up into OD at about 4k rpms, but it simply wouldnt shift at WOT, do I have to feather the gas a bit to get it to shift? Is OD really made to hold power in a 700r4 though?
I have been looking for the rev limiter in the code 59 xdf, but have thusfar been unsuccessful in finding it.
-Jason
supersports10
Re: Rev Limiter?
ahhhhh this is tranny related then.... gm has a upshift valve that cures this problem, mine did the same thing, and the sleeve and valve fixed it.
dBaseD
Re: Rev Limiter?
Hmm, well it makes sense. I just had the transmission rebuilt by a local guy here when the forward planetary went defunct...
Just installing the upshift valve and sleeve should fix it?
-Jason
supersports10
Re: Rev Limiter?
-Jason
even though i completely trust my tranny builder, i would never let my sy/ty valvebody out of my hands.:squint:
i would have had him rebuild the trann with a spare valvebody installed, then swapped them when i got home!;)
TYTILIDIE
METH HEAD
Re: Rev Limiter?
I dont think youre doing that bad. What stall is your convertor? I looked over your log and then compared it to mine. On my older runs when I had the 2500 stall I was getting 4500 RPM. Now with hte 3000 I can get 4800.
dBaseD
Re: Rev Limiter?
Your guess is as good as mine on the converter. :dunno: Its a Kenne Bell 300HSL. the 200HSL was a 2500-2800 stall for a turbobuick's 200r4, so I would imagine this is the same specs, but for a Sy/Ty. Probably just a modded orange stripe at any rate.
For the most part I would tend to agree with you, but my mechanic is a good friend of mine. Hell, he even drove 40 miles one night after midnight, after picking up a trailer from a buddy of his to come pick up my mustang at Moroso so I didn't have to get it towed when I blew the head gasket. Thats the kind of person that helps you bury dead bodies. :lol:
supersports10 said:
would you like me to get the upshift valve?? i can get them for 50 and some change last i knew.
Thanks for the offer, but I should be able to source them around here somewhere. If not I will let you know :tup:
-Jason
