Davemc1963
93 Ty Owner
Re: rocker adjustment
Sounds like that you have either set the valve clearances at a point other than at 'true' tdc, (slipped balancer) or you have set them too tight. You need to set them like Don W explained in post 31. If trying to adjust after the pushrod just stops rotating freely can be difficult unless you are experienced.
Often, lifters will bleed down and the only resistance left within the lifter is the very light spring within it. Then, in this case, the only time you feel resistance to rotating the pushrod is when you have bottomed out the plunger. Then you will add another turn on top of this, resulting in the valve being held open. If you adjust 1 full turn down after the pushrod just stops 'moving up and down, you will be ok.
One turn from zero lash puts a stock lifter pretty much in the centre of its travel. Others do less. One turn down works for me and is nice and quiet.
