Rocker stud repair
qbnkiller
Conflaguration Specialist
Re: Rocker stud repair
ARP head bolts are to be torqued to 63# with their lube. I have gone to 70#, but I wouldnt go more than that. ARP studs are a bit more...80# with their lube.
Quickstop [UK]
Combating adversyty.
Link? All mine are ARP studs with cometics at 65 lbs.
As for ARP being harder and then stretching, that doesn't make sense.
turbodig
That pretty much jives with what I remember doing.
I'm adding the 2 ft-lbs for RTV being used as a thread sealant.
Thanks for the offer on the head, Alex... I got my head back. I really need to start paying closer attention to voice mail, it was actually done around noon Tuesday, the day it was dropped off.
I had to wait on a head gasket anyway (should be here today, supposedly), so it really wasn't a big deal.
As it turned out, there wasn't ever a helicoil in there... what pulled out, was the original threads in the cast.
I suspect that the casting there was shaky originally, and too many cycles of stud removal did them in.
It was actually a good thing that it made me remove the head - I found the funky lifter issue, found an exhaust leak on the turbo flange, and found that my previous repair on the turbo drain leak didn't work.
Would have rather had a few extra days padding to get it all back together, though...
turbodig
Well, the delivery services are again screwing with me... this time usps.
Tracking # Hood sent says it was dropped off for ship on the 26th. Supposed to be delivered on the 29th.
(Even says expected delivery, on the 29th)
No sign of it anywhere.
Going to shake down the post office early tomorrow, hopefully I can catch it before it goes out on the route, I won't see it until 1:00 PM if that happens.
I was actually hoping it would have gotten here when it said it was supposed to, I could have made some progress tonight. Sucks.
sytyguy
Moderated User
D@mn Dig....I'm sorry to hear that. I even grilled my shipper to ensure that it would arrive by yesterday.
Though, I wish I could say I'm surprised.....
nallj92
what kind of head gasket are you getting? can't you source it locally also? or is it a MLS type thats not reg stocked? If you need one from the cities i can pick one up on the way up.
turbodig
The Factory Victor. #5855
Local places all told me it would have been 8-9 days to get it here, of the ones that could get it.
The dark side of this is that I don't know for sure it will show up tomorrow. If it doesn't show until Tuesday, it'll probably make getting it back together and cleaned up/loaded up not a possibility.
Curious if you could even find one in the cities.. what time are you planning to come up here?
I do need a (one) NGK UR6 spark plug also, if you have one or can get one down there. No local places stock them ("we can get 'em in a week"), and I only had 5 in my spares.
I've got everything cleaned and ready to go back on, so i'm just sitting waiting on the gasket.
turbodig
Not your fault, dude. I knew something was fishy when they said it was to be delivered on the 29th yet it got checked in in Jacksonville on the 28th. That's a long way to go in 1 day.
nallj92
I'll be heading up tomorrow and hopefully getting in Fargo 7-8ish. I can stop and get the plug. I could get a gasket also. if we dont need it i could take it back later. Lemme know and I should be able to get it done.
turbodig
The gasket came in, I was able to intercept it at the local PO this morning. Head is on the block, sequencing and torquing now. The ground and clamps on the back are going to be a PITA.
Thunderboomers up here now (and supposedly most of the day), Justin. I've got a garage stall for ya here if Jim doesn't have indoor parking for ya.
Back at it...
phoonTy
Truckless. For now.
Back at it...
Awesome news Dig! You can do it! :lol:
turbodig
Top end all back together, rockers adjusted, gonna put the covers back on it. :tup:
Buncha hook up and hoses and etc, but it's really looking viable now.
Still got the dissy to stand on my head and put back in.... ugh.
turbodig
Very nice dig, make sure to bring lots of beer :)
Roger that... just had a few pints of really cold Nordeast, which was awesome. Might bring some of that along.
As of 11:30-ish, she fired and is running. Still needs the upper IC put back on and a few misc brackets, and a really good underhood bath. Timing will have to be reset.
The lifter ticking is gone... this is the quietest it's been since the engine rebuild.
Should be able to get on the road Wed. sometime, although I haven't shaken the 'burb and trailer down yet.
Big thanks to Jim (95xtreme) and Justin (nallj92) for the help on the reassembly, and making sure I didn't gloss over stuff.
Quickstop [UK]
Well done.
This highlights how many people have bad liters as there were a few people that seemed to think it was normal for the ticking noise. Injectors, yes, ticking no.
Regardless, I love it when a plan comes together!
