WyoSyclone
Re: RPM Stage1 Turbo Install...
One last pic....
The wastegate actuator rod needs to be bent about 23 degrees, then the rod end for the actuator rod is also bent 23 degees.... this makes kind of an 'S' curve out of the whole mechanism so that it will line up properly with the wastegate lever...
I broke two of the rod ends trying to bend them, so finally just brazed the tab on the rod end jigged up at 23 degrees - no binding, works perfect!
One last pic....
