Coming home from the track last night (3rd place :tup
truck started running real lean, almost to the point of dieing, at part throttle. Just before manifold pressure crosses over from vac to boost it will smooth out and run just fine. All my FT runs last night were right at 12 flat.
I don't think it's a vac leak because it will idle, barely, at the correct RPM but of course I will check. Just driving it's as if the it's either the MAP sensor or TPS. Fuels pressure is correct.
I will do a DM run and and see what comes up but meantime if you want to throw some ideas out I'd appreciate it.
Thanks.
Thanks.
