BMFB
Not to scale
ok, so im getting ready to start running code 59, theirs just a few things im not sure about, and thats
the fuel pressure regulator
the wideband o2 sensor
the stock ecm as it is now.
ok, so the wide band, I was thinking that it was going to replace the narrow band, but the more i think about it and look into it, that doesn't seem the case, it looks like its supposed to be there just to compliment the narrow band, and that i have to cut a new bung into my down pipe, am i correct?
next, i got a new walbro pump, and i was thinking that I needed to run a new adjustable fuel pressure regulator, but i haven't really seen that written anywhere. i was under the idea that i should be turning up my fuel pressure to my injectors, so I thought I should ask.
next, the ecm, I know that i have to rig in the wideband, and that the stock chip gets replaced by a G1 adapter, but is that it? do i have to make any other changes? I cant seem to find anything that leads one way or the other, so I thought I would ask
what im looking for with this is to keep full street-ability and be able to run maybe in the 13 flat area, I have a 3 bar map sensor so I can take the boost pressure up a bit as i need to but the motor and everything else is stock. but yea, any help is always greatly appreciated, ive been digging around but I always find stuff that kinda counters what other stuff says...
