Someone identify this tranny
s_blazin
only thing i know is it is NOT a TH350 and definitely to small to be a TH 400,
this thing is the exact same length as a 2wd 700R4, but it's a 3spd
s_blazin
Re: Someone identify this tranny
i thougth a 200r4 had 4 gears? this one only has 3,
and that spacer in between the main case and tail shaft?
what the heck is that for?
just to make it longer?
sytyguy
Moderated User
Definitely has a 13 bolt pan, and the only trannies that GM made with a 13 bolt pan (and the cut corner) were the TH250, TH250C, TH350, TH350C, CBC350, and TH375B. It' not BOP pattern and it doesn't have lockup, so we can throw out all but the TH250, TH350, and CBC350. So.....probably a TH250.
SY2455
70's Veteran
It could be a 200C or a 250 C from the mid 80's RWD. Most likely from a Camaro base on the tailshaft housing.
Ry368
one mile = 5280 feet
It looks like a TH-200 to me........Competition, Super Stock and Stock Eliminator racers use them A LOT!!! I can lift my buddies up with on finger and install it by hand without a jack, but it has been lightened and beefed up for psca racing!
UR50SLO
V6+2=LSXCamaro
I was going to comment on that 3dgen tail shaft housing with the 3 bolt pattern there too.
If it's not a 350 then it'd have to be that other one. (looks like a 350 really.)
200R would have 4wire connector and no vaccume line.
Good luck,
Scott~
s_blazin
It's not a "C" because there is no electrical connector. It has a removable extension housing, so not a 200. Not a 400-style output shaft diameter, so not a 375. And last but not least, it has no kick-down cable, so NOT a 350 of any type.
By eliminating everything it's not, It's a TH250.
actually you can't see it in the pics but there is a kick down cable, but i still bet you are right about being a TH250, what did those come in?
