Spider cracks - refinish cladding ?
hatrik8
Some parts of my front bumper have spider cracks on the surface. Is there a way to get rid of these without painting or major body work? Anyone ever refinished the stock cladding or is it better to just get a replacement piece?
NecroWolf
lost marbles member
Re: Spider cracks - refinish cladding ?
sand the paint down, repaint w/ a flex agent in the paint
DaveP
Never put 'flex agent' in the base coat. And the agent is only recommended for use in the clear coat if the part will be 'flexed' excessively during re-installation of the part after painting.
Flex agent reduces the clear coat's resistance to UV degradation. This is probably what your "spider cracks" are, if they're on the entire surface, not localized from impact: UV degradation.
My recommendation is to sand the existing coating until as much of the imperfections are removed without getting into the base material. Then prime with DP-50 (black) or NCP 235 and sand again to 400. Base and clear with no 'flexative'. Let dry only 24 hours. Install carefully, with a minimum of distorting the part. Don't let anyone back into it after the car is in service.
I don't like Flexative. Too many negatives to using it. Mostly spider cracks if it spends much time in the sun.
:2cents:
Dave
Tooky
Serious about performance
Hey DaveP I thought you were all about "factory original". I'm fairly sure the TSB for cladding refinishing doesn't mention anything about a clear coat? Wouldn't that give it a gloss look instead of the factory matte finish? But I could be wrong.
DaveP
You make me laugh, Tooky. I DO like factory original.:tup:
You are correct, the OEM paint was single-stage. But there are no longer any metallic formulas available in single stage. All current-formula metallics require a clear coat now. At least in California.
BUT: There are low-gloss clear coats available. My favorite is PPG 2060 Flex-n-Flat clear. Mix it 90% 2060 with 10% 2020 Concept, and you will get a very close 'gloss' level to the original LG 9098 (Typhoon gray). Straight 2060 is too dull.
I don't remember what the TSB called out for the 'color' on Syclone black. I vaguly remember thinking "NLA" when I read this TSB a while back. I've seen a WA 848 for the black, but haven't confirmed that's the original formula. (I don't think it is). But even 848 is a BC/CC formula. And it's black. Not the gray-ish black of the raw cladding color.
If your spot-repairing, or only doing a partial re-paint, then it will require shooting some test panels to get the mixture (percentage) correct to match the gloss. But that's only if you can match the base color. And on a Syclone with original raw cladding, I wouldn't attempt to match it. I would refinish the entire set. And the best way to match or blend 'gloss' is with a BC/CC system, where you can fine-tune the gloss. Just takes time........
Regards,
Dave
turbodig
Regards,
Dave
If memory serves, the TSB specs DDL 9862. I haven't been able to find this anywhere, or even a replaced-wtih number.
My cladding was supposedly repainted with this. I kinda wonder if it actually was. It was *very* dull when it came out. A bunch of buffing got a semi-glossy result.
Tooky
DaveP
DDL is PPG Acrylic Laquer. Hasn't been available for 10-15 years. At least in California.
This material IS very 'dull' when first applied. It needs to be color sanded ("rubbed"), and machine- buffed to make it gloss. VERY labor-intensive, and touchy, but when executed by a highly skilled master, the results are show-winning. This was really good paint. Not all lacquers have a cross-formula. And a lot that do, aren't the same 'color' in the replacement formula. Perhaps why 9862 is 'un-available'.
Tooky said:
What do you want pics of, Tooky? Anything I can provide?
hatrik8
So basically I shouldn't bother refinishing to a stock look it if I just end up painting it black down the road. Thanks for the info.
turbodig
I was afraid you were gonna say that. I was hoping I could pick something up such that I could get a good match on the bumper cover. Yck.
Tooky
I think any pics of cladding (from you, Dig, or anyone) where we can see the quality of the finish, would contribute to the thread's value.
turbodig
The current finish. I like it... it's shiny, but not body-painted shiny. It's a very difficult thing to take a pic of.
I'll snap some of the bad spot, also.
Got a pic of the pre-paint faded cladding, too, gotta dig it up.
cheatham2492
Has any body had any success with this cladding match?Recently?I have to do the same.Had a little boo boo pop out at me .
Dumb #*(&&^#^
Thanks
