stalling when engine warm
92Ty#1524
Ive had issues with the engine either stalling or not wanting to start at all when the engine is up to temp. It usually happens after it has sat for a few minutes (ie, run in and out of a store). Idle is noticeably rougher and slightly lower when it finally starts.
Major mods include 3 BAR map, 50# injectors, Ultimate chip, Crane cam grind HR-194/271-2-12, L35 block and heads (not totally sure about the heads), headers and .030 overbore.
Ive never noticed it before because it hasnt been a daily driver until recently.
Any ideas?
Jack
Maxtor
If everything used to be allright - and now it's not - you may want to check the coolant temp sensor on top of the engine next to the t-stat housing. I had one flake out and gave me similar probs on my daily driver s-10.
doomdead
Re: stalling when engine warm
Any ideas?
Jack
You get it figured out??? I'm having similar problems.... Too many variables to figure out, theres ticking under the top manafold when the ign is on... and last night i had the bright idea to go out and cyles the ult chip through all its modes.... viola, truck starts up... (oh ya btw it had been dead all day).... this all started after blowing the ecs fuse.... so now im having real fun trying to track it down.
Buster
Any ideas?
Jack
Take a look at your data logger next time this happens (after it finally starts), check to see if the integrator is running straight up to 218, and then clicking back to 128. For some reason my truck has done this in the past, same exact same scenario. Drive to gas station, turn truck off, start truck and it starts misfiring like wild fire, once the integrator finally settles back down, it runs fine. Sorry but I haven't found the solution as of yet.
92Ty#1524
Buster, I'm guessing that I'd need Datamaster or a comparable program to check that? If so, no can do at the present. I'm really itching to get it and find the smoking gun, though. As of late, its a daily driver and I need to get this issue and my detonation problem resolved before the hot weather hits Houston, ya know?
I havent been able to narrow the problem down yet but Erik is having a similar problem.
http://syty.net/phpBB2/viewtopic.php?t=24054&highlight=stalling
We have the same chip/injector combo and developed this problem after the upgrade so I'm sitting back to see what happens with his before I throw any more money at parts that probably dont need to be replaced.
smeagol
Mark's got a custom chip setup, which probably has some similarities to your calibration, but has been tweaked.
Jack are you running one of my programs? If so, see what version chip you have, by looking on the label on the eprom.
Erik's was due to calibration, which is sorta resolved (gonna get him an update).
92Ty#1524
Brian. I believe it's your program. I bought it about 2 years ago and initially had problems with it because I had a problem following directions (as you may recall) :oops:
The sticker on it reads "50# Cam" and the date "12/27/01".
doomdead
I know this subject got off my problem, but i thought I'd post to say, the new waterpump is in... althought it seems to be the IAC thats causing the trouble... i'll know more tonight/tomorrow...
