stalls and sputters when hot???
psmvchaser
Anyone have any ideas?
My Ty runs great, except when I drive it for over 30 minutes and turn it off. If I restart it, the thing stalls and I have to give it a lot of gas to keep it running. The engine temps are the same, and I have a fairly new fuel filter, walbro, and #50's. It has a pretty recent tuneup also.
Its so hit or miss that I can't figure it out. Just wondering if anyone has had a similar problem.
Ken
denny
Re: stalls and sputters when hot???
Same here, it all started right after I switch over to 50#er
I use to run better without the msd6al but now its the same with or without.
I changed all the ignition comp (cap,wire , plugs etc) including rebuilting the distributor , same shit.
Sometimes I just wanted to drive it over a cliff but there are no cliff where I live so I might just set it on fire.
Denny
ty369
psmvchaser
Nice. I'm running a 6AL also.
I guess I'll have to stick with the short trips and no restarts.
Denny
ty369
nightdiver
She needs some tuning to stop doing that. Its fuel/temp related. Im sure this wont happen in the winter. I had to pull the "start IAC" almost at the top of the map to make it start without depressing the gas pedal and im using 95s . It might need some extra tuning at the cranking VS coolant temp map also
Im running a Fast ecm though
I had a problem like that when I switched over to 50# injectors. It turned out the the burn on the chip was bad. The truck would turn on but not idle at all once it got warm.
denny
Not to steal someone else post..
I been trying everything,
for me, its not the chip.
I had stg 50lber I went out and buy a PhilL 50ller , same thing.
Now I got an extra chip to sell !
Jamerjoe
Did anyone figure out what the deal was this this? Mine does the same in reverse and drive when I restart it when its still warm, but once I get moving its run great. Even at idle without giving it any gas. Can it be heat soak on the wires since I have not protection on them?
psmvchaser
Cant say that I found any specific problem, but I did get a custom tune from Nolan and I've never had the problem again.
Goshinki
Randomly just started to have this problem as well.
Nothing has been changed...
20g Turbo, Walbro, 2600 Stall TC... is all I have with a stock chip.
I am going to do wires, plugs and cap here and see what happens... (I did this about 3 months before... and this problem just started a month ago...)
My issue seems to happen right when the intercooler kicks in though...
Beavis
Still plays with trucks
Then I would check for a leak in the intercooler first....
turbodig
I'm guessing they have very similar fueling in the higher-temp areas.
A large majority of the chips floating around have similar or the same values in the cruise/part throttle areas.
A bit of tuning can usually clear these issues up. I find that the low RPM areas tend to go a bit lean when hot.
Most of the 50# chips out there were open-loop, so they had no way to correct for it.
denny
Thanks, this is an old post, I have BS3 now.
