Methuselah
<update> Even more issues, please read below <update>
Last night I fixed the issue with fuel squirting around the tops of the injectors (not an insignificant effort, and the fuel rail itself needed to be bent to an appropriate angle). Anyhow, I was finally ready to start the truck.
When I hooked the battery up I realized there were no interior lights. I checked all the fuses, scratched my head, and eventually got lucky when I found that I had not connected the red/black wire. I attached it to the +12V terminal on the firewall and everything seemed fine. I turned the key and the fuel pump primed the rails, and then nothing happened when I tried to turn the engine over.
And then things started getting wierd. I turned the key back and tried again, at this point, all of the lights went out, and the "Anti-lock" light came on and stayed on. That was it, just that light. I uplugged the battery, plugged it back in, and just the antilock light came on. I unplugged the battery again, waited for a long while, unplugged the red/black connector from the ABS unit just for kicks, and started screwing the ground terminal back into the battery.
As I was doing this, the cabin lights came on. Just after this, I touched the wrench to the body (screwing in ground) and this caused a bit of a spark, and the cabin lights went out. With the battery still connected I found that the engine was at +12V relative to ground.
How could this have happened? I realize that I could have connected some wiring incorrectly, but why did everything seem to work up until I tried to crank the engine, and then all of a sudden the vehicle isnt grounded, but instead at 12V?
Thanks for the help,
Seth.
________
Yamaha blaster
Seth.
________
Yamaha blaster
