starting problem
mildtowild
Custom Upholsterer
since i relocated my battery to the trunk, i have a occasional problem where it will click but not turn over. gets worse when it is hot. I used 0 gauge wire. I am thinking possibly a bad crimp on the starter?
gkrcr882
SyTyless......for now!
Re: starting problem
Did you already check the purple wire? IIRC, it's the one that has a tendency to get fried on the DP and cause the click click when hot.
UR50SLO
V6+2=LSXCamaro
Also make a Negitive wire from Battery to body.. then right under that go from body to frame.
Up front make sure the frame is connected to the engine block with big wire as well.
And a decent size wire from frame up front to body.
I bet that's where it's coming from.
~Scott
:2cents:Just FWIW I put my bat in the bed also. Ran a new wire to starter of course. Used the frame for a ground. (Motor to frame and then frame to bat.) But since you loose the bat + wire to the alt I also had a new one of those made that goes from the alt to the bat connection at the starter. Interestingly my DataMaster shows a noticeably higher and more even voltage during WOT that previous runs with the original bat setup.:2cents:
Flyin Ryan
hated cuz he drives fords
Here's how I have mine ran.. all with 2 gauge cable/stock alt for two years no problems but eventually went with a 140 amp alt because of voltage spikes by my efan.
Also all ground wires are also 2 gauge and I forgot to put in the picture that I still have the stock ground strap on the driver side head to firewall as well.
Daryl H
Have you ever tried to see if the kill switch will work if the engine is already running?
Unless you have removed the original alternator wiring I think it will continue to run.
Sy-1177
Turbo Inside
:2cents:But since you loose the bat + wire to the alt I also had a new one of those made that goes from the alt to the bat connection at the starter. Interestingly my DataMaster shows a noticeably higher and more even voltage during WOT that previous runs with the original bat setup.:2cents:
This is where my issue was too. My wire from the alt was too small. Bumped it up to a 4gauge and BAM, 14.4 at the battery! I've been chasing that issue for a while now and it made a huge difference as stated above. I still get the occasional starter click as you mentioned, but it got ALOT better.
Although I didn't test this I was told by an alt shop that this was true. Also, and more important, do not just switch the alt output wire. If you do and you switch off the truck using the cutoff you will get a voltage spike (+30 volts) in the alt which will kill it. You must switch the alt field wire.
Daryl H
Couldn't you just move the alternator feed wire to the cut off switch to the battery side of the switch?
Hmmm, this might be a good idea actually. As long as the wires that feed the truck from the alt are fed from the "switched" side of the switch and not the alt. This could be done with a wire from the starter without having to go all the way to the switch. The wire from the alt to the bat side of the switch would have to be of sufficient gauge to prevent voltage drop to the switch at the rear (per NHRA). Did I miss something??
mildtowild
Custom Upholsterer
Well, i figured out what was wrong and it was option c: stupid installer. some how forgot to tighten the setscrew all the way down on to the cable at the battery clamp. my disconnect fuse is on the short negative cable. only 18" of cable, and when it is off, there is no running.
Daryl H
Not too many choices on disconnect switches that can handle a high ampere continuous load....but that is how I have mine set up. 6 gauge wire from the alternator to the battery. 8 gauge wire from the original battery post wires (minus the starter wire) to the battery. Solenoid for the starter cable.
