I stumbled upon this thread, not sure if I can shed too much light at the moment, but I'll do what I can.
We only sold calibrations for stock injectors and 50 lb/hr injectors.
The stock injectors were closed loop, similar/identical to stock in that respect.
The 50lb/hr calibrations were made open loop. That was a decision on my part, and could be argued whether or not it was good/bad/correct. I had very good luck with open loop, and bad experiences with closed loop on syty's. I'm going on the assumption you have one of my 50 lb/hr calibrations.
- Warning - going off on a bit of a technical rant/tangent here..
Quick background, hope I don't get much wrong here, as it's been years and years since I worked on a syty calibration.
Syty's have 2 block learn values. This is a long term fueling trim really, usually represented as LT or LTFT in other forums/discussions. One value is used at closed throttle (idle), the other is used at open throttle. My big complaint of this configuration was that the program attempted to make long term fueling adjustments for ALL conditions where the throttle would be open using a single value. So if you took a long ride cruising at 1800 RPM, and it was *slightly* rich, your BLM/LTFT would go lean (<128). Next your driving condition changes... and you have a slight stumble at off idle, or it's really lean at 3400 RPM.. because your BLM/LTFT is "fighting" you and is removing fuel for the condition it learned at the 1800RPM cruise. I had similar experiences with the STFT, where it would cause rolling conditions. Now you can play with the parameters in the chip for a long time, try adjusting PID stuff, or what have you. I did some testing and really liked the experience of open loop. I liked having my truck idle *slightly* richer than stoichiometric. I liked having it cruise slightly leaner than stoichiometric. It felt smoother not having computer correction involved. Also, the 50lb/hr calibrations were geared towards people with heavy modifications, where emissions was a secondary concern. They also had the goal of allowing for some adjustability. The instructions were that you could adjust fuel pressure for best idle/drivability, and then scroll through the programs for WOT fueling adjustments. I don't have the exact calibration program mapping, but it was along those lines.
I believe it's accurate here:
http://www.sytychips.com/50lbdescription.html
As far as specific calibration questions from gearhead -
The 50lb/hr calibrations were set to open loop fueling in all but the valet program. Are you getting your LT/ST data from a scan tool or from the calibration? I believe I just set it to open loop based on coolant threshold, not by locking STFT/LTFT values (but I could be wrong). Meaning, the closed loop flag would never be set, the values would read 128 (or zero) depending on the scan tool. The valet program would be closed loop, and should have stock-like values for closed loop operation. I don't recall anything changed as far as timing goes in the valet chips.
I would start with a stock-like base fuel pressure on these programs (43.5psi line off). The idea was that a stock-ish truck could get away running without an adjustable FPR, but might not have the full adjustability offered if there was one installed. This is assuming the truck has a stock motor, and running the Delphi/MSD 50lb/hr injectors that the calibration was based on. If I'm wrong on either of those counts, you'll need to get some sort of custom calibration done.
