Re: Still have knock ....
Mike said:
Why wouldn't i be able to run the ultimate with an RPM stage 1? Its not too much bigger than the stock one. The ultimate calls for the base FP to be at 50. Should i try to turn it down a little?
This seems to be the biggest thing that people don't understand about chips, and how our engine management system works-
If you change something, and don't change the chip, something will be off.
In the case of the ultimate, the one you have was set up for a stock motor, and a stock turbo. You added a larger turbo, which moves more air, but the chip didn't change. It thinks it's still getting the same amount of air.
This isn't just true of the ultimate, it's true of virtually any chip that you'd buy from anyone.
You can buy a chip from people who will sell you a chip for x injectors, turbo y, and cam z.
Even if that matches what you have, it's a complete crap shoot as to whether or not it'll actually work.
Unless you sent someone a data file of how your truck runs, and they send you a chip based on that data (and usually several repetitions of this), you're not going to get something that will work well.
Some people get lucky, and an aftermarket chip will work with what they happen to have. This is by far the exception, not the rule. Maybe 5% of the time, at the most.
This is why people are slowly coming around to the truth, that the only way to fix it right is to tune the chip to what you have. (Either by doing it yourself, or paying someone to do it)
As an aside, trying to use fuel pressure to change fuel is liketrying to fill a 55 gallon drum with a shot glass. If it's close to where it needs to be, you can do some good, but if it's waay off (which it usually is) you can't do enough to effect it.
