Stock boost limit.
92BlkTy
how far does the needle go at full boost? mine seems to spike up to about 14, but hangs arround 10-12 when its floored. i know the stock boost gauge is very innacurate, could this be what it is? i really dont want to hear that im not making full boost :x
sytyfreak
Stock boost is 15 PSI (14.7 actually). Have you done any recent tuneup to your truck??? Try to get/borrow a scantool and do a complete tuneup. It will really help and eliminate alot of problems to your truck...
B
Blake
Guest
13.8 psi is max stock boost programmed into the eprom.
10 psi max points to a failure somewhere in the boost control solenoid circuit(vac leak/solenoid failure) as this is base stock boost of the spring in the "puck" that the wastegate rod goes into.
Troubleshoot as per manual.
Blake
sy112
13.8???? I agree with sytyfreak, the most a stock truck will READ is 14.7 with 2 Bar MAP. As I understand it though, you can easily overboost but your truck will not actually show because it can only read 15lbs. Just do a search and you will come up with a lot of threads, but more likely than not it has something to do with your ignition. Seems like 98% of the time it is something with ignition. If you don't have a scantool(turbo-link, datamaster,etc.) seriously think about investing in one. Not only will it keep tabs on day to day stuff but can effectly help you tune to make the most out of your little brick rocket. Have you heard any audible knock, what octane gas, recent tune-up? Go to http://www.sportmachines.com/maintenance/beginner.html
and do do all what is noted and your truck should run like a top(on steroids) :lol:
BTW 1 bar is 14.5psi, Blake is correct about 13.8psi. the stock ecm call for ~95% for a boost target which is approx 13.8psi
92BlkTy
well if it will only go up to 13.8 then im right on the money. i was scared i wasnt doing full boost because i wasnt geting the needle to peg at 15, and when im on it, it hangs between the 10-15 mark. since theres no numbers on the stock gauge i cant be %100 on where it is, but if its 13.8 then that sounds right. i need to get data master and a decent boost gauge. today i noticed that it was in the vaccum part when i could clearly feel it start to boost. :x
Flyin Ryan
hated cuz he drives fords
Remember, it is said by most that the stock boost gauges sucks major azz. Don't trust it ever just make a boost gauge your next mode so you can effectivly monitor boost. My stocker before the 3bar mod was off by a decent amount.
B
Blake
Guest
Get datamaster and promgrammer. Load a stock BBZB bin into Promgrammer and look at the F77 or F71 table(I think, it's been a while). All the boost levels are in that table. Max is 13.8 PSI. You can program it to max out the 2bar sensor but GM set it for 13.8.
If you go over 13.8 psi for "x" miliseconds by "y" amount (KPA) you will get a code 31 (overboost)
Datamaster is awsome when you need help over the internet or someone is making a chip for you. You just record the truck in the condition you are having problems with and ask for help using it. Its amazing what people can help with when you give them the right info.
BoostedPimp is absolutely right. Get a boost gauge. Stock gauge is for looks only. GM added the boost gauge to go along with the Tach for "sporty" Sunbirds. Our trucks use the same gauge cluster as the old Pontiac Sunbird. That's why your gray plastic bezel sits on top of the dash instead down into it. Compare yours to an s-10 sometime and you'll see.
Myself and InvisiBill make adaptors for Datamaster if you decide to go that route. Bill Calcagno makes Promgrammer and many of us have a plethora of BINs to wade through for learning value.
Stick with the stock bin, use an Ultimate or use the ATR pitbull. These are the only three that seem to work for people.
Started rambling. Didn't mean to go past the question you asked.
Blake
sy112
Thanks for the info Blake, I didn't know about the 13.8 ecm. Now that is where the ECM is trying to maintain, but does a stock truck usually over shoot that? I know from previous post that our boost control pretty much sucks in stock form. Why I was wondering is, when I bought my truck it had the Ultimate V6 I believe and it was getting mad KR and basically not running good due to neglect. So I took it off and went back to stock with 2 Bar and am trying to get it running decent in this setup before moving to ultimate. When using the ultimate I had pretty decent boost control, but when I went to stock, it was like I was having no boost control at all. SEVERE overboosting. Now I am running a grainger valve just to keep it under control until I get it lined out. What kind of problem does this sound to you, bad solenoid? I have patched all vaccum lines and done the recommend tune-up.
92BlkTy
actually i noticed the dash piece siting on the dashpad when i first go into the first ty i test drove because i drove a 94 s10 blazer before the ty. i thought it was a little odd, but i found out that day they were turbo sunbird clusters. thanks for the help, im actaully working on getting an autometer boost and trans temp gauge right now 8)
B
Blake
Guest
Don,
Check the wastegate rod adjustment. They may have played with it to get it where they wanted it. You did put a 2 bar map back in it, right? Many people forget to do that when they go back and forth.
Something many people don't check when overboosting is the boost control cutout relay on the firewall. It is right next to the CAC relay.
It may be sticking.
Now the 13.8psi is just a single setting in the eprom and can be readily changed just like an Atari cartridge(I'm old). Timing was something that really changed from eprom issue to eprom issue for the syty. Ron Gregory did a small writeup on it years ago. ECM is separate and same one was used in 4 or 5 vehicle types.
Blake
sy112
Yeah I went back to 2 Bar MAP. I really haven't been ableto trouble shoot the problem to much as i am tryingto get the KR lined out. I just thought it was weird having boost control under the Ultimate but none under stock chip. Makes me wonder if the eprom might be goffy or something. I have a friends computer, may try hooking that up to see if it helps.
I did play with the wastegate rod a little, but only while using the grainger though. Tightened it up just a little, between doing that and the grainger I have awesome spool up :fadein: And I will definately check the relay, I would like to get it lined out where I am using the ultimate to control boost, don't want to have to buy an external wastegate. I plan on going PTE eventually and I understand they have pretty good boost control, so I don't really see any sense spending extra money.
Daron
My wastegate gets sticky now and again. This causes some odd boost control problems. I think this is a problem on many of our trucks with stock turbo's. Check the wastegate arm's movement when truck is warm.
JNR
Sy112, your problems seem to mirror mine exactly. I have been having problems with what I believe is overboost and fuel-cut under WOT using the stock FBC solenoid. I have gone through everything in my truck from full performance tune-up, timing etc, to new fuel pump and most recently finally installed my ATR aux I/C kit.
Interestingly, I found that by installing a precision ball and spring MBC set at around 14.5 psi my truck seems to run without a hitch. BTW I am running a stock chip right now with factory turbo, cat, and ATR exhaust. The MBC is the only thing to date that has given me relief from my cut-out issues. An MBC is a pretty crude tool I guess, but it does provide a reliable boost ceiling once you factor in a small amount of spike and weather-related adjusting requirements.
I had originally checked my WG rod and found that it was set with 0-pre-load. I dialed-in a little pre-load on the spring and my static boost at full flow-through to the WG canister is about 7-8psi so I know the WG setting isn't causing the problem. I do have a NOS boost solenoid sitting in a box that I might try just for grins I guess.
Blake: I am really interested in this boost control cut-out relay, can you elaborate on this item? I hate to just gun-deck problems, but it might be worth it just to replace it as my truck has 94k on it and relays do get pitted and sticky over time.
sy112
JNR
I think I might have seen your sy before. I did the Osh Kosh Bgosh there at the outlet store and was driving to home depot and saw a sy right off of 70 I believe. Have you had your truck long? This would have been maybe a year ago. Thought about swinging in and talking but never got around to it. I definately know the hassle of over boosting, and sounds like we are using the same MBC to me. Hell these things may be crude but they do a good job. Mine hold pretty solid boost, less than half a pound varience adn minimal spikes on shifts. Thinking about playing around with drilling a smaller bleeder hole to see if it helps with spikes, I drilled mine with .020 but am thinking about trying .017. Think I can only go so low though, but am really interested in getting my boost set by the ultimate until I do go PTE.
JNR
Sy112, didn't even take note that you are located in Kansas! I have had my truck since 99. Not too many Syclones around these parts, so it definitely could have been my truck.
I am using an XBC brand MBC which worked great on my stage 3 WRX and I figured since I had it sitting in my spare parts box I would give it a try. Man I am glad I did, because the truck is running well now with maybe a .25-.50 boost spike max.
I have always preferred letting the ECU control the FBC, and until the WRx had always shyed away from MBC's and other stand-alone boost controllers.The WRX taught me a lesson though, and that was that if the FBC solenoid was substandard to begin with then having a piggy-back or re-programmed ECU was still going to net you poor boost control due to the weak-link FBC.
I hear a lot of folks talking about the internal WG of the stock Sy/Ty turbo being a weak link for being able to get consistent boost control. I believe its definitely less effective than an external wastegate, but I have to wonder if the FBC isn't a big part of the problem as well.
I am in the process of getting my truck to the point of change-over to the ultimate/3bar chip set-up similar to you. I already have the 3-bar map sensor, and am getting ready to order an AFPR next week. So heres a question for you. The ultimate chip recalibrates against the 3bar map sensor, and fuels/times accordingly. I realize that Ultimate V6/V7 has some nice boost maps to drive the FBC, but since the 3bar map sensor and fueling are exclusive of the actual boost control, it would seem like you could easily run an MBC( or perhaps a beefy twin solenoid EBC like a Blitz SBC-id, or DBSC, or Greddy Profec B) and still enjoy the benefits of the 3bar fueling capabilities over 14.7 psi.
I guess I just don't trust the FBC much at this point.
Well keep me posted on your progress with your Ultimate and I may be picking your brain as well when I get ready to make that move!
BTW: heres my email address for future reference. Also if you are going to be in the area drop me a line, and maybe we can hook-up!
jredding@usmo.com
Ps- also take a look at the latest from Hallman! http://www.boostcontroller.com/
The remote adjuster version MBC is very cool! I have been thinking about buying one for my EVO since I have the XBC in use on my Sy!
Later!
