stock converter, cam options?
BMFB
Not to scale
hi there!
Im in the process of getting my ty engine rebuilt, and id like to do something with the cam, but i know messing with this will alter my power curve, and therefore the way i launch, because of my torque converter lockup.
now i dont mind sticking with a stock cam profile, but i cant find what exacly that is, so i was wondering if anyone had any recommendations on what kind of cam i should use in conjunction with the stock converter. (sounds dumb but the other reason i dont mind staying stockish was the truck was way faster than i was already expecting, and really its all i need)
little background on my truck, its a ty, its stock other than an exhaust, some ic work, and the use of code59, with which ive been running my boost pressure up around 18psi. I also have a walbro 255 pump. The rest with the motor is probably going to stay stockish, with the addition of some eagle I beam rods, and maybe some forged pistions, although i need to also figure out exactly what our compression ratio was to stay close to stock...(8.38 to 1, right?).
BMFB
Not to scale
Re: stock converter, cam options?
what about the comp cam listed on the combination thread, the first one with the 407/427 lift?
BMFB
Not to scale
Ive seen alot of stuff about cams on this site but not much about matching the converter to them, i was just seeing if anyone had any experience with an aftermarket cam with the stock converter.
BMFB
Not to scale
nope, im in flint michigan, they dont care about anything here lol
just dont want to go over what my stock heads can take, and i dont want to loose my launch
It's just a six
Super Member
Around 204 duration @ .050 will work fine.
IIRC,stock cam has about 173 degrees duration @ .050? Anyone?
BMFB
Not to scale
ok heres what i found so far...
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=556&sb=2
its numbers are something like duration at .050 is 206/206 and lift is .425/.425
its a comp, only thing is it says its for hydraulic flat tappet, and believe its a roller motor...
other one is http://www.edelbrock.com/automotive_new/mc/camshafts/cams_chevy_6cyl.shtml #2112
duration is 204/214 and lift is 420/442, also listed as being a flat tappet...
thats what ive found so far...i also believe i do not have a balance shaft motor, as i think the balance shaft would have gone through the lifter valley, and there wasn't anything there...
id like to get a crame powermax 2020, its listed on here as being a great cam, but i cant find for sale anywhere on the internet...
pontiacws699
my understanding is if you dont do anything to the heads a cam wont do anything for you?
BMFB
Not to scale
well, im sure im not going to get a bunch more performance out of it, but really im just rebuilding the motor and im trying to stay as stock as i can, and i dont know where i can get a stock cam and roller set for a 93 typhoon...so (from my understanding) forced to go aftermarket...unless reusing my 80K mile cam in my fresh motor is a good idea
gkrcr882
SyTyless......for now!
No reason why you can't re-use it. So long as you re-use the lifters, pushrods and rockers you should be fine.
It's just a six
Super Member
I do not like the lobe centers personally for either cams..or a split pattern camsahft either.
I like a lobe center of 114 or more for a daily driver.
You do need more duration to help w/the top end pull,that's why I stated about 204 in 204 ex. degrees duration @ .050. .
The stock heads are the big restriction,that is why adding a bit more duration on the camshaft will help overcome the stock heads short commings.AKA ,bad flow.:2cents:
That was the duration camsahft Kenne bell had for an upgrade over stock & w/there tests improved the top end pull. 204 duration @ .050,,, IIRC.
Stock is a roller cam, you don't need to reuse the lifters etc like with a flat tappet cam.
If you use going to use code $59 you can get away with a bigger cam. (for those not using code$59, stick with stock cam with the stock chip)
You will get some gain with some lift (pretty much any lift because the stock cam has lift number of .359/.390). IMO The difference between .450, .500 and .550 will be negligible. The majority of the gains with be longer duration. I have 214 duration cam and I think I could get away with the stock stall converter if needed. You probably can't go wrong with the cam you mentioned or a comp cam 412 as long as you have engine tuned for it.
