Re: stock injector ultimate+50lb injectors+e-85..
supersports10 said:
awesome.... i already run my truck on e-85, with the stock injectors, and stock ultimate.
if i were to run the stock injector ultimate with 50# injectors it would be way too rich with gas, but e-85 requires appx. 30% more fuel
if you add 30% more fuel to our stock injector rating of 33.5#
you get 43.55 that it would need for a "stock" truck, that runs stock boost.
i dont run stock boost:rotf: i regulary run 22 psi, and sometimes 24....no alky
but with stock injectors i have to jack the fp to 62# base fp
otherwise it literly just flatlines in the higher revs...===out of fuel:tdown:
with 50# injectors, i could lower the base fp to stock...something like 42-43 and have a decent running truck.:tup:
It'd certainly be lots better than running it with your stock injectors.... that's a burned piston waiting to happen.
Decent running? I guess that would vary greatly depending on your definition. I would say
not even close to decent running, but I have pretty high standards. (I expect the thing to
not die at stoplights, idle well, and not blow itself up)
Stock fuel pump isn't rated for alky, neither are the walbros. You'll need to resolve that first.
I do know that a mildly built motor with a TE-44 will run out of fuel on e-85 and 50# ers.
At about 17 psi.
You can calculate all the numbers you like when it comes to fuel... it doesn't matter.
Your numbers won't be close to reality, and you're making some huge assumptions as
to what the motor's needs are.
I did a lot of testing with fuel pressure and AFR years ago... 5 psi of fuel pressure =~ .08
AFR. 10 psi of fuel pressure =~ .15 afr. Most trucks are 1.0 or more AFR off the mark.
You're throwing lawn darts at a Abrams tank, trying to fix fuel issues with fuel pressure.
Bottom line, start with the Mototron 60s, at the minimum. You may need more fuel than
that, but at least it's a better start.
Then, you'll need to tune it, or have it tuned. Do not delude yourself into thinking that there's
some plug-in combination of parts and chips that will make this behave well, because there
isn't. 2% of the population will get lucky and have it drive ok, but it will never perform well
or drive like it should until you tune it for fuel you're running.
Furthermore, you can also then do a tune to run regular gas, and have a switch to go
between the two. The best of both worlds.
