stock injectors running 11'S??
Gnocide
turbo game burt reynolds
CURIOUS...
who has done this
and
what is your combo (TURBO /TRANS MODS)
and settings for doing so(f/p/ timing/ chip etc)
please refrain if you truck is bored out to the max/ not using the factory intake/ or heavily modified heads that don't bolt up to the factory intake/ or if motor is in a sand rail
thanks
Re: stock injectors running 11'S??
Hey, where did my name come from. LOL
Yes Jeremy's truck runs high 11's on stock injectors and a ton of meth. Without meth it wouldn't work. At this point the injectors are maxed out. I have tried to add more fuel and it just doesn't happen. There are a set of 50#'rs in the works to head onto his truck next year due to this.
This is stock motor/heads/turbo never been apart. Motor anyways.
I would not suggest it. For the cost of injectors it is not worth risking a motor going lean if your going to push it and spend any real time tuning.
I know Tooky 11.79 PT51 and Madmike 11.75 TE-45 had their Sy into the 11's with stock injectors as well.
Ian Turgeon
Cascading Inspiration
Dig has been there as well.
AFAIK, its not safe or reasonable on stock injectors alone (assuming your truck isn't 1900 lbs.). There just isn't enough fuel. Everyone I can recall is using meth to add fuel (and other benefits) at that speed.
Gnocide
so mid/low 12 is more reasonable then??
if more people have done low 12s on stock injectors- what is required?
epix
Typhoon
alky injection for sure, larger turbo (20g minimum?), 3 bar map, aux intercooler and pump, wideband 02/ostrich or similar setup, walbro 255, afpr, LOTS of TIME and TUNING
Six-is-Enough
Use to do a little Boost
I found a couple of issues since the last time the truck was max out injectors.I had installed underdrive pullies and they were keeping the altenator from keeping up the volts.
Low 12's are doable with stock injectors only. Alky can get you into high 11's with stockers. Tooky runs a dual jet alky system which can get you to mid 11's. But you will be livin on the edge.
turbodig
Except me, of course... I gotta screw up the curve. :)
I ran 11.84 on the stockers. Of course, I had the base FP at 60, and a really evolved tune.
Race fuel, no alky. 20g, 9/11 converter. Sticky tires. Dual fuel pump. Really well built trans. Stock exhaust with a "transparent" cat. Stock air box intake.
In practical terms, 12.2x or so with a Sy, and you start hitting the wall.
I've had lots of trucks do mid 12s on stock injectors, over the years.
My current mindset is either run the stockers, or the Mototron 65s. (down to the high-10s, anyway) The rest you can just pitch over your shoulder.
I'm guessing we'll see larger hi-z offerings soon... the flex fuel mandates will mean lots of cars will need more injector capacity. (At least until DI motors become prevalent)
HighPerformanceTrucks
Lift & Shift Specialist
I ran a 12.0 on stock injectors. Would have run into the 11's if I didn't have a parasitic power robbing transmission. TE-44, stock motor.
Key was a proper tune. Ultimate ver 7
C-16.
Water injection.
