Rexxenexx
The Ty hasen't been started for a real long time. I put a new battery and a little more oil in it then tried to start it. The engine turns nice over but doesn't start. The gas level was pointing to the sky so I tought maybe the gas was too low. So I put almost 5 gal of gas in it and tried again but it was the same. Gauge was still pointing to the sky. I put a light test on the dist. and then from the coil and got nothing so I went and bought a new coil. When I cranked it it still didn't start but the gas gauge went to a little lower than halfway so it was finally working. Another thing I tried was pushing the shrader valve on the fuel rail while the key was ON and fuel did come out so the pump is working. I want to put a pressure gauge on the valve to see if it has good pressure but I don't have a p. gauge. What do you all think is a good place to look?
