Suggestions on Timing??
WyoSyclone
Hi Guys,
I've been doing a lot of tuning with Code59 (I'll post this over there too). I've gotten my AFR, boost, and driveability tuning done. Now I'm working on timing, which will later affect boost and AFR again, but that's another story. I can't seem to get over this hurdle...
I thought my Sy may have had a problem with baseline timing (the prior owner had the engine built and they didn't put a timing pointer back on). So, I bought an aftermarket pointer, devised a way to check top dead center - http://www.syty.net/forums/showthread.php?t=59551 -
and proceeded to check my timing tonight. Turns out my TDC contraption worked perfectly and my baseline timing is exactly at TDC.
So, here's my problem... I'm only running about 6 degrees of advance at WOT. We all know this is a very bad thing for exhaust valves, etc. This screen shot shows how I'm just on the verge of knock retard (in this run I get 1.2 degrees).
This shot shows my timing advance at the same frame of the DM run...
And, this is my timing map. Of course the values are low in a lot of areas, but I do have the ramp up of timing that is required as RPMs increase.
And here is my DM run - a little bit of cruise, stoplight, around town, then out to my local test area.
ooops, can't get this to upload
A couple of things - my compression seems high. A check of all cylinders show them reading between 167 and 171... this would equate to an approximate compression ratio of 9:1 through 9.3:1 if you use the typical divider of 18 or 19.
My intake temps are reasonable although I'm going to try and get them down further.
I'm limited to using Shell 91 Octane fuel - best there is here.
I do have an Alky kit on order from Julio, but it's not going to be installed till I get my timing dialed in with the current configuration.
Any ideas would be greatly appreciated!!
TYTILIDIE
METH HEAD
Re: Suggestions on Timing??
I would say regardless you are not running any where near enough timing. Why do you have it set all the way down at 6*? I am wondering, what are your AFR's at WOT with that 6*? Try this table.
I get very little knock between 17-19 psi with this table and we are up here at 6000 feet. I also use Shell 91, all we have here as well.
WyoSyclone
Thanks for the quick response Mike. I took my original spark table, added 2 degrees across the board, and ended up with 1.6 degrees of knock retard across the entire run... so I know I'm up against the limit as it sits. I'm running 11.2 AFR's at WOT 168kpa and greater.
I'll email you my DM run. If you have time I'd appreciate another set of eyes looking at it!
WyoSyclone
Hey Mike,
Is this map set up for spraying methanol?
TYTILIDIE
METH HEAD
No it is my non meth table. It is what I am currently running til I get my alky controller back. I dont mind looking but my email is different than what my profile says. It is now htlandscape@yahoo.com. Send it over. There is no reason you shouldn't be able to run at least 13* at that MAP range.
Tooky
Serious about performance
Did you ever run high octane gas in the truck?
How much knock did it get on the stock chip and stock injectors?
6* of advance, just seems astonishing. When you connect the tan timing wire and shoot the balancer with a timing gun, does the advance show up?
WyoSyclone
Hey Josh,
I'm getting this thing worked out..... never did run race gas (none to be found around here - in quantity anyway), that's why I'm stuck with tuning to 91 octane. Tried octane booster but once I did the math realized that was fruitless.
My Sy never had the stock injectors and chip.... had 40's and the KB chip in it when I bought it.... this is what made me jump on the Code59 bandwagon so quickly.
I've actually got it dialed up now to where I'm running between 9 and 14 degrees at WOT with a max of 1.2 degrees of knock. I did about 20 runs over the weekend to get to this point. Of course it's running a lot stronger now..... I figure about 4 or 5 more runs and I'll have the timing and this BIN maximized. I finally found a hill with enough grade to give me some part throttle loading, and I'm down to doing highway speed downshifts and getting those dialed in.... all in all it's running great!
TYTILIDIE
METH HEAD
Rob, I just now looked at your DM file you sent me. You need more timing all the way across the board. What kind of gas mileage do you get? Just curious. Just by looking at your run and seeing what the truck is doing at what points, it would make me think the truck runs very smooth but thats about it. I.e., smooth, but kind of flat and dead. Also, I noticed you barely run 12-13 psi., is this normal for you? Last year I uploaded your bin in to my set up and while I tuned around it fuel wise I left the timing table alone. The end result was a flat running truck. I would give it gas and even though it felt smooth, it NO ooompff. Here is an example, in the 60-80 MAP range you had like 15* of timing. Now see I thought this was a good thing but when I got Cheatham in my truck he told me it was insane to have it that way. I let him drive while I ran the laptop and every time I bumped timing up a few *'s it got nothing but better. Felt amazing. You barely had to have your foot on the pedal and speed would increase. I added even more timing a few months back and got my timing table, what I consider to be, pretty much dead on. I am very happy with it. Sorry it took me so long to read your run, I forgot all about it and have been really busy forgetting things :lol: Let me know if you need any more help. I don't have all the answers but can tell you what has worked for me.
cheatham2492
Yes mike you are insane!!!
Trucks very accordingly but as a rule the more timing you have the better throttle response you have. at low map ranges you can have as high as 40 degress but under full load it will drop to around 16 hopefully...Now here in town "Aurora" without meth i could run no more than 12* @ WOT or it would knock like heck.
My cylinder pressure was around 150-160 on a newer build.
It would be benefical for 9.0 compression you gain a lot in the lower end before the turbo kicks in which is 90 percent of where most of us drive.
Cheatham
