WyoSyclone
Hi Guys,
I've been doing a lot of tuning with Code59 (I'll post this over there too). I've gotten my AFR, boost, and driveability tuning done. Now I'm working on timing, which will later affect boost and AFR again, but that's another story. I can't seem to get over this hurdle...
I thought my Sy may have had a problem with baseline timing (the prior owner had the engine built and they didn't put a timing pointer back on). So, I bought an aftermarket pointer, devised a way to check top dead center - http://www.syty.net/forums/showthread.php?t=59551 -
and proceeded to check my timing tonight. Turns out my TDC contraption worked perfectly and my baseline timing is exactly at TDC.
So, here's my problem... I'm only running about 6 degrees of advance at WOT. We all know this is a very bad thing for exhaust valves, etc. This screen shot shows how I'm just on the verge of knock retard (in this run I get 1.2 degrees).
This shot shows my timing advance at the same frame of the DM run...
And, this is my timing map. Of course the values are low in a lot of areas, but I do have the ramp up of timing that is required as RPMs increase.
And here is my DM run - a little bit of cruise, stoplight, around town, then out to my local test area.
ooops, can't get this to upload
A couple of things - my compression seems high. A check of all cylinders show them reading between 167 and 171... this would equate to an approximate compression ratio of 9:1 through 9.3:1 if you use the typical divider of 18 or 19.
My intake temps are reasonable although I'm going to try and get them down further.
I'm limited to using Shell 91 Octane fuel - best there is here.
I do have an Alky kit on order from Julio, but it's not going to be installed till I get my timing dialed in with the current configuration.
Any ideas would be greatly appreciated!!
