Re: Switching to 75#ers...
SCWolverine said:
You're right, but I didn't (no further reasoning). The driver/sense resistor rework on the board is no problem, and from what I understand P&H is gooder anyhow (even if not necessary). I'm still looking to connect a few dots regarding the wiring changes (Sunbird). My summary, questions...
Connecting D5 to D6, and C13 to C15 create the sense current for each injector driver.
C11 and C12 are common (syty), which we don't want. So? Tie 468 (DK GRN) to C10 (per the SB diagram)?
This was discussed on code59 a bit already.
If it were me wiring it up, I'd use both C10 and C11, 3 injectors a piece. This would imply a bit of re-wiring, as the stock injector harness goes to all 6. Find a chunk of harness out of any non-sequential V6 (any port 2.8/3.1 that uses a '730 should have one).
I see a lot of people that put both injector drivers in, and then saturate just the one by using the stock SyTy wiring. Makes no sense. (no pun intended)
I'm not aware of many (any?) set up this way. I think most that are running big injectors are probably saturating, and the ones that are running P&H correctly are hanging all 6 off 1 driver.
I don't think anybody would see the ECM heating issues if they were wired properly. There are 2 drivers in the system, you might as well use them.
Part of me wonders about running saturated injectors off both drivers. I would think the open/close speed should improve, since there's less of an inductive load hanging on each driver.
Later,
