Re: vortec swap
Re: vortec swap
cool beans glad to see the cam being used cant wait till running videos.
Re: vortec swap
Ouch. I dont think piston should look like that. Any thoughts? DM showed no knock when motor gave up the ghost.
How long ago did the motor pooch on you? looks like its been like that for a bit, judging by the soot on the first ring groove and the side of the top of the piston starting to round off. Also because of the angle the where the break is next to the first compression ring its looks pretty flush. Might have been cause by detonationand and it kept chipping away at the piston.
Are you sure the knock sensor even works?
One of the guys I know took out the second LS based turbo'ed moto,r before he realized his knock sensors were defective
You mentioned that before the engine let loose you were running real fat 9.1. You can also hurt the engine this way. The extra fuel washes oil off the cylinder walls and causes the rings to stick to the wall under load. Most of the time it cracks the ring lands. Normally you see the ring blues or the molly on the rings is worn off. The second problem is you end up with tons of fuel in your oil witch will kill all your bearings as the oil thins out.
Just thought id share that with you! GLW the new motor.
