Sy Is Finally Done (Again)
mrweelr
Today was a good day. I installed the PST carbon driveshaft and backed the truck out of the garage under its own power. The truck was absolutely filthy from sitting for so long, so I gave it a quick wash. Tomorrow, it's getting aligned and I plan to drive her around some. Going to top off the tank with 100 and see how the 80e performs. This was a long, expensive and grueling project, so I'm very happy to have it completed. Need to go find some good methanol for the Razor injection and then resume tuning with Nolan. Should be seeing a new personal best very soon - as in 10s. Might drive it to work this week if the weather cooperates. Here are a few pics...will post some better ones after I detail it:
chelo
filthy sy
Re: Sy Is Finally Done (Again)
looks real good. If a swaybar would work with the battle bars I would install one. A few weeks back I installed a swaybar on my sy and man does that rear end feel diffrent.
mrweelr
And here's the mile long mods list:
-Sunbrella Custom Car Cover
-Chrome Fire Extinguisher
-RK Custom Floor Mats
-VentVisor Window Louvers
-Tinted Windows (50%)
-PPG Windshield
-GMC Truck "Motorsports" Tailgate Decal
-Kenne Bell Battery Relocation Kit
-ATR Chrome Differential Cover
-ATR 3" SS Exhaust
-ATR Radiator Hoses
-PowerMaster Chrome 200A Alternator (38203)
-Painless HotShot Starter Relay (30202)
-Racetronix Dual Walbro Pump Wiring Harness
-Walbro 255HP Fuel Pump (x2)
-Detroit Turbo AFPR
-Optima RedTop Battery
-Sony M670 CD Player
-Pioneer TS-P462 speakers
-Kenwood KFC-415C speakers
-Sony XPLOD XM-1S 4-Channel Amp
-Momo Champion Steering Wheel W/Hub
-LoTek 3-Gauge Pod 2 1/16"
-AutoMeter CF Boost Gauge (ATM-4703)
-AutoMeter CF Electric FP Gauge (ATM-4763)
-Autometer CF Trans Temp Gauge (ATM-4757)
-Autometer Trans Temp Send Unit
-Vacuum Distribution Block
-KYB Monomax Shocks
-PST Front Suspension Kit
-PST Idler Arm
-Moog Pitman Arm
-Power Performance Extreme Duty Ball Joints
-Baer 13" Track Brake Kit
-7/8 Rear Brake Cylinders & Raybestos 514 Shoes
-Aluminum Brake Drums
-ABS Delete Kit
-RPM R-505 18 x 8", 18 x 9" Wheels
-Kumho Ecsta MX 240/40/18 and 275/35/18 Tires
-Chrome Lugnut Kit W/Locks
-Belltech 3" Drop Leaf Springs (BEL-5954)
-Goodmark Cowl Hood
-Checkmate FX Tonneau Cover
-ACC Molded Replacement Carpet
-Tahoe Mini-Starter (6449S)
-MSD Pro Billet Distributor (8367)
-MSD Blaster Ignition Coil (8226)
-Borg-Warner Select Cap & Rotor
-JS Solid Motor Mounts
-Derale Trans Cooler W/Fan (13700)
-Derale 180F Inline Thermostat (13021)
-B&M Trans Cooler (70266)
-Jegs Remote Transmission Filter (71-10678)
-Blitz SBCid II Boost Controller
-Dynomax SS 3" Exhaust Band Clamps
-RPM EGT Probe Kit (ATM-5244)
-RPM 3" A2A Intercooler
-RPM Turbo Oil Filter Kit (K&N HP1008)
-Braided Hose and AN/NPT Fittings
-RPM 3" Catalytic Converter
-RPM Brake Booster Hose
-RPM EGR Blockoff Plate
-RPM 8mm Plug Wires W/MSD Separators
-ITS IC-TB Transition Hose
-ITS Minigate 38mm Wastegate
-Thermo-Tec Exhaust Wrap, Spray Coating
-DEI Fire Tape + Heat Wrap
-Razor Progressive Alky Injection System
-PLX Devices R-500 WBO2 Computer
-DiamondBack Crystal H4 Headlamps
-Sylvania SilverStar H4 Bulbs
-Sylvania SilverStar H3 Fog Bulbs
-Altezza Black Tail Lights
-Super White Bulbs (Entire Truck)
-Typhoon Mirrors
-Lund Backdraft Tailgate Spoiler
-TurboTime SS Radiator Support
-Ramchargers Dual-Electric Fans
-CBR Battle Bar Traction Bars
-Edelbrock Polished Alum. Water Pump (8891)
-Billet Specialties T-Stat Housing (BSP-90420)
-Throttle Body Plate (Intercooled)
-Throttle Body Bored 52mm, New Seals, Air Foil
-Xtreme ZQ8 Steering Gear
-Dorman Power Window Motors
-DEI Fiberglass Plug Wire Sleeves (DEI-010502)
-NGK TR6 Plugs (4177) Gapped @ .025"
-March Billet Aluminum Pulleys
-Spectre Magnabraid II Engine Dress-Up Kit (SPE-7498)
-Billet Specialties PS Reservoir Cap (BSP-89120)
-Billet Specialties Radiator Cap (BSP-75120)
-AMI Billet Aluminum Master Cylinder Cover (AMIC-30001P)
-ARP 12-Point Polished Stainless Engine Bolts
-Hypertech 180F Thermostat
-RPM Street Terror Motor (JE Extreme Duty 9:1, Oliver Rods)
-RPM Vortec Heads with ARP Studs and Cometic Gaskets
-Comp Cams Camshaft (Nolan Custom Grind)
-Comp Cams Pro-Magnum Lifters (CCA-875-1)
-Comp Cams Pro-Magnum Pushrods
-Comp Cams Pro-Magnum 1.6 Roller Tip Rockers w/Poly Locks
-PT72GTQ BB Turbo (Polished and Ceramic Coated)
-RPM 1.625" SS Vortec Headers (2000F Coated)
-Stage 8 STG-8951 Locking Header Bolts -
-QTP 3" Electric Exhaust Cutout
-RPM 3" Downpipe (2000F Coated)
-RPM 75# Fuel Injectors
-RPM Billet Fuel Rails
-RPM Custom Fuel Lines and Dual-Pump Assembly
-RPM Steering Shaft
-RPM Sheetmetal Valve Covers
-RPM Coil-Over Front Suspension
-RPM Chromoly Crossmember/Driveshaft Loop (Powdercoated)
-4" 90 Degree Intake Elbows
-K&N 4" Conical Air Filter (RE-0870)
-K&N Engine, Tranny, Turbo Oil Filters
-Summit Aluminum Overflow Tank (SUM-300100)
-Moroso Aluminum PCV Catch Can
-Tial 50mm BOV & Flange
-S10 Replacement Radiator (No Heater Core Fitting)
-B&M SFI 29.1 168-Tooth Flexplate
-Nolan ECM Driver Mod and Custom Tune
-Prime Gears Street/Strip 4l80e w/3200 Stall
SY-1193
Very Nice! Go enjoy driving it. - (as all of the rest of us on jack stands are jealous). Congratualtions!
R&C_RallySyTy
Little Big Man
Very well done. Clean engine for having AC, what made you go with the 72GTQ dual BB? What turbo did you have before, and how does it compare?
Ry368
one mile = 5280 feet
:thumbsup:Your truck is looking good! Clean trucks like yours make me proud to be an owner of these little beasts!:tup:
:cheers:Thanks for sharing your pics and mod list.
bezerk
i have these taillights also, they look better irl. i can't have them to fot, since they added an extra bulb into mine for braking lights..no room in the new ones. oh well..
syty9933
wow ver nice ,the bottom is as nice as the top , where did you get those window covers?
