Syclone cab removal
tunerpike
Just looking for some advice. I would like to try to get this done today.
I have a cherry picker and was thinking about running a strap through the cab and maybe a few towards the front cowl to support that weight.
Any advice s appreciated.
Thx
GEMELLI
The Best of Both Worlds
Re: Syclone cab removal
I'd be a bit leery about strapping it though the door openings. You definitely don't want any damage there. Assuming you don't have a buddy helping out, I'd run the straps completely under the cab. :2cents:
Norm
If I was going to do it, I would use a floor jack and lift the cab up abit and put some blocks under it, then when it is high enough, use the cherry picket and use the straps as a sling to pick it up evenly.
tunerpike
I here a Harber freight looking at my possibilities.... How much do you guys think the can weighs.. Full interior.
Snoman002
I don't think there is anyway to do using a cherry picker without damaging it somehow. You MIGHT be able to do it but the risk is so high I certainly wouldn't attempt it. Heck just scuffing the paint is a couple hundred dollars to repair, and it only goes up from there. That's too much money for me, personally I would pull as much of the interior as possible and the get 3 friends to help me take the shell off. Make that 4 friends. Pull the bed, 4 guys lift the cab, one guy rolls the frame out from under it.
If I HAD to use a cherry picker I would run some 4x4's under the cab bolted to the mounts, then straps from the cherry picker to bolt in eyelets on the ends of the 4x4's. Never would I let straps touch the sheet metal, nor would I lift from a nonstructural location.
What's the point of pulling the cab if the interior is staying in it? If its interior work the interior is coming out anyways, if its frame or drive train work none of it would be so hard to do with the cab in place that I would risk major damage to the cab to save the hassle of working around the cab.
tunerpike
Bed, front clip, motor and trans are all out off/out of the truck. I'm not too concerned about the paint as it will be getting re done.
As soon as I can get the cab off I'm rolling it out side to bead blast the frame and paint it.
This is a ground up build.
Snoman002
Makes sense now.
I would run some 2" straps under the cab then. Scuffs sent going to matter so the straps rubbing sent going to be a problem. I would see if you can keep the straps on the mounts if at all possible, with the interior in it there is a bunch of weight there and I wouldn't trust any of the sheet metal to hold that weight.
tunerpike
I believe I'm going put a strap on each side, possibly lifting up on the cab and placing the strap between the cab and frame pads. I just bought a load leveler to assist in the weight offset from front to rear.
Also, bought some car dollies, plan to take the tires off and just let the rear drums rest on them to get the frame lower to the ground.
My backup plan incase the cherry picker doesn't work is to use my floor joist in my house. I know, I know... doesn't sound like a good idea. I bought a universal winch mount that's about 2.5' long and .25" thick to help distribute the weight across the joist if need be. The joist in my house are two 2x12 sandwiched together.
What do you guys think?
budmann2002
its freakin heavy, I did this by myself with my s10. the only thing I had was 3 2" ratchet straps and one 3" overhead pipe. I wouldn't recommend using a cherry picker. make a call to a few buddies and pick that thing up. run a couple 2x4 boards under the cab and pick it up. then you could set the cab on some furniture dollies to move it around somewhat easy. just my 2 cents. it aint a fun job by any means
GarnetTy1473
How about lifting the whole truck up, put jack stands under the pinch welds on the body, unbolt it, then drop the truck. Only problem you'd have is when trying to roll the chassis out from under the cab the stands will get in the way of the wheels.
gstacky
I would attempt something like this, but instead use some 12 foot long 2x4's under the cab, with something large to hold them up over the height of the frame, then simply roll the frame out from under it. Or a second cherry picker for the other side, and straps under to a picker on each side. Or empty the cab, and 4 guys can easily lift it.
tunerpike
I appreciate the replies... Looks like i'm going to hold up until I can get a few more guys to help
Norm
I took the body off the frame on my ty. I used a floor jack and 2x8's. I can post up a pic if you want one. But is was a back yard job at the best.
Adam#0213
This truck is awesome!!
That looks safe!
I ran an old LVL through my cab on my S10 (94-up extended) and picked it with my backhoe.... no issues. It was easiest to lift the cab and roll it out.
I did this three times on two different cabs, doors were off and the interior gutted.
Sportmachines
Heres how we have done it over the years:
A lift is best and easiest. Put it on the pinch welds, lift and roll out.
We have used a cherry picker to help other owners that didn't have a lift at their disposal. Put the straps through the cab with the doors open. Not through the window openings on the doors. Use the wider, heavy duty straps, and X them. that way you can adjust the tilt, etc with a click of the ratchet.
4 guys can lift the cab with the full interior in it. Its heavy, but very doable.
You can use the jack stand and jack approach as well, but ill need to put boards across the pinch seam and put the stands outside of the wheelbase so you can easily roll it out. And the rocker cladding has to be off the truck.... I'd have it off for all of the above, just not worth the risk of damaging it.
Also have used a back hoe. Actually used the front bucket. Strap on each end of the bucket, down and around the cab. Have done the same with blazer bodies. One around the front under the doors, another strap through the wheel opening. Works well.
HTH
HTH
