2500avalanche
Well-known member
Re: Syclone cab removal
Be safe when doing any of this. It is heavy, and can be unstable. Be smart and safe!
Heres how we have done it over the years:
A lift is best and easiest. Put it on the pinch welds, lift and roll out.
We have used a cherry picker to help other owners that didn't have a lift at their disposal. Put the straps through the cab with the doors open. Not through the window openings on the doors. Use the wider, heavy duty straps, and X them. that way you can adjust the tilt, etc with a click of the ratchet.
4 guys can lift the cab with the full interior in it. Its heavy, but very doable.
You can use the jack stand and jack approach as well, but ill need to put boards across the pinch seam and put the stands outside of the wheelbase so you can easily roll it out. And the rocker cladding has to be off the truck.... I'd have it off for all of the above, just not worth the risk of damaging it.
Also have used a back hoe. Actually used the front bucket. Strap on each end of the bucket, down and around the cab. Have done the same with blazer bodies. One around the front under the doors, another strap through the wheel opening. Works well.
HTH
HTH
So your saying that the roof is strong enough to support the weight?
