Syclone died today at the track FIXED
First pass, not even half track it's like I shut the key off. After getting towed off there's no spark. I tried a different (unknown) module. No help. The track was kind enough to lend me a closed shop. Have to work tomorrow but hope to have her home tomorrow evening. I'll let you know what I find. I have fuel pressure and the dist turns so it's not that. So ya wanna bet? Module? coil? MSD 6al? The ghost of Syclone ignition? News at 11:00 as they used to say, or maybe later.
blacktyaffair
Re: Syclone died today at the track
I'll guess it's ignition related. If you can, check to see if you have injector pulse. Not sure if you can use anything other than a noid light tho. If no injector pulse, I would suspect module or pickup coil. Good luck Don, keep us posted.
bezerk
my digital 6 took a crap as well, wit the plug and play harness you can outtake it in a couple of seconds.
Didn't you post just a day or two ago how reliable your truck was and how many passes you had made?
#1 Rule of owning a syty, NEVER EVER compliment your truck.
Don Wishing I didn't say good things about my truck said:
Yikes!! This Dec it will be 9 yrs for me. Just looked it up. Can't believe it. All I can say is any post of mine more than a year or two old should be disregarded as I'm still learning. With probably over 100 1/4 mile passes this year and still going strong truck has served me well this year.
Flyin Ryan
hated cuz he drives fords
MSD = May Suddenly Die
That's my vote and if you have the plug and play harness then just unplug the 6al and by pass it with your stock ignition
ViciousV6
400HP/550FTLB
when i ran my box always had it easliy disconnected so i can go back to stock and still get home if need be.
If you can't that would be in my plans to make it so you could just delete box and run stock ignition set-up.
Most likely box, module generally won't die in the middle of action, always on a start up.
Ralph
ViciousV6
Osmosis
I had the same thing happen to me on my way to work:roll: I was driving down the hwy on my way to work and it was as if someone shut off the key. I had to have my TY put on a flat bed tow truck and put back in the garage:( I checked fuel pressure which was good, but then I had no spark.
I went to auto zone & had my ignition module and coil checked. Both were good. NOW WHAT?
I replaced my distributor and now she purs like a kitten.
First thing, take that MSD box off and connect it to the stock ignition set up. If it runs, you found yoru problem. IF not, I would replace the distributer as that was my fix.
Yes I did say how well the truck was running... :)) No news. Only worked 12 hrs today. Got hung up in The City. (San Francisco to you east coasters.) Truck is home though. Company graciously let me use one of their roll back's (AKA car carrier, we just don't haul cars.) Hopefully tomorrow will be a shorter day and I can fix it.
FIXED! It was the coil. Sorry it took so long, to much other stuff going on. In doing all this I discovered that the center term of the cap is virtually gone. So now will be a good time for a real tune-up!
Re: Syclone died today at the track FIXED
Is there a low OHM cap available? Or need to replace center carbon piece in cap?
Not that I know of. It's either MSD $$$, copper term parts house brand $$, or steel term parts house $. I'm replacing the copper house brand with a copper house brand and will keep closer track.
Cool. That was easy. Was it a stock, or a May Suddenly Die coil?
I've noticed that the center buttons on the caps last about 75,000 miles before they are burned up into the cap. That's with stock ignitions, and on all my 4.3's, not just the SyTy's. I change the cap every other spark plug change. Because my plug-change interval is 35-40K miles, this works for me.
DaveP
MSD coil. The truck has a TOTAL of less than 75k on it. But it is raced a lot. I will definitely be keeping closer track of the cap. BTW when I switched to an MSD coil a few years ago the first one was inop out of the box. I run the 6al to have the 2step. Otherwise I think I'd remove it as well. Coil is now BWD O'Reilly's top of the line. Seems to have good reviews. We'll see what how it goes. I swear the thing felt heavier then I remember the MSD. That would be good IMHO. I'll weigh them as the new one is just sitting there at the moment.
It's just a six
Super Member
I have had friend use an MSD 6a & 6AL box SBC's & the center of the distributor cap would melt becuase of the high resistance the center carbon piece would have.
I remember MSD used to sell there own low resistance center carbon piece that would eliminate the cap from melting.
Maybe it's not an issue anymore?
I have had friend use an MSD 6a & 6AL box SBC's & the center of the distruber cap would melt becuase of the high resistance the center carbon piece would have.
Maybe it's not an issuse anymore?
Interesting point. The only local parts house that I know of didn't have our cap so I went with the store (copper) brand. After I've run this for awhile I may buy an MSD and see if there's any difference.
