gringo76
selling my syclone,
around 90k on body if I remember correctly and here are a list of the mods.
stock block, stock crank, h beam rods, diamond pistons, howard 4 bolt splayed mains, arp studs, 96 vortec heads, steve morris cam, double roller chain, roller rockers, stock lower intake modified by member on here, twin 58mm throttle body, sportmachine after cooler with fan, precision 63mm turbo, precision 39mm waste gate, 3 inch turbo back exhaust with borola muffler,msd billet distributor, msd coil, msd 6al box with two step, turbo tweak chip, 80 lb injectors, walbro 450 in tank pump, #8 feed line, #6 return line, turbo tweak adj fuel pressure reg, a/c delete, 4l60e rpm stage 5 trans just refreshed by them, 3600 stall precision triple disc lock up converter, rebuilt transfer case, aluminum drive shaft, hd prop shaft, rpm stock radiator with there twin fan setup, aem wide ban wired for computer to rum off of, rpm coil over kit with control arms, rpm torque arm cross member delete kit, bell tech rear sway bar, nichie 3 piece 18/10 , 18/9 rims, plus all the stock parts, factory polished rims, extra rpm stage 1 58mm turbo, alky meth kit. body has been painted somewhere in its life, I sanded and buffed and is pretty nice, goodmark steel cowl hood, flush fit painted bed cover, all ground effects are nice. Iam sure there is stuff I have forgotten about and will add as I remember but a very complete built truck that's very nice and just needs no be enjoyed! 18k firm in no hurry
pics to follow
I will post more pics upon request
all ready remember something else. got some renz brake brackets front and back still in the box
pics to follow
