syclone f/s
gringo76
selling my syclone,
around 90k on body if I remember correctly and here are a list of the mods.
stock block, stock crank, h beam rods, diamond pistons, howard 4 bolt splayed mains, arp studs, 96 vortec heads, steve morris cam, double roller chain, roller rockers, stock lower intake modified by member on here, twin 58mm throttle body, sportmachine after cooler with fan, precision 63mm turbo, precision 39mm waste gate, 3 inch turbo back exhaust with borola muffler,msd billet distributor, msd coil, msd 6al box with two step, turbo tweak chip, 80 lb injectors, walbro 450 in tank pump, #8 feed line, #6 return line, turbo tweak adj fuel pressure reg, a/c delete, 4l60e rpm stage 5 trans just refreshed by them, 3600 stall precision triple disc lock up converter, rebuilt transfer case, aluminum drive shaft, hd prop shaft, rpm stock radiator with there twin fan setup, aem wide ban wired for computer to rum off of, rpm coil over kit with control arms, rpm torque arm cross member delete kit, bell tech rear sway bar, nichie 3 piece 18/10 , 18/9 rims, plus all the stock parts, factory polished rims, extra rpm stage 1 58mm turbo, alky meth kit. body has been painted somewhere in its life, I sanded and buffed and is pretty nice, goodmark steel cowl hood, flush fit painted bed cover, all ground effects are nice. Iam sure there is stuff I have forgotten about and will add as I remember but a very complete built truck that's very nice and just needs no be enjoyed! 18k firm in no hurry
pics to follow
I will post more pics upon request
all ready remember something else. got some renz brake brackets front and back still in the box
gringo76
18k firm, its at the bottom of add
found hood strut kit also and will be installing in next couple nights.
it also has dual trans coolers with dual fans mounted under bed along with rear battery mounted under bed too.
gringo76
Re: syclone f/s
forgot to mention in add, this has a e-85 tuned truck with a turbo tweak chip in it now along with a e-85 plus the alky kit tune in second position but decided not to use the alky kit but come with sale. if some one wanted a gas tune I also have a spare turbo tweak chip that can be sent off for a gas tune.
Sean Krupa
Moderator
Re: syclone f/s
Sweet lookin setup! Love the wheels. Glad to see my old Turbo again haha. Good luck with the sale :tup:
gringo76
Re: syclone f/s
thanks, got too many projects going , as soon as I get her together I put her up for sale lol, some one will get a good truck.
gringo76
Re: syclone f/s
found some more parts that will go with it. two spare torque converters, one is a b&m 2400 stall for the factory 700r4 and other is a single disc lock up that came with the 4l60e when I got it, of coarse it now has a new precision 3600 triple disc lock up. also have the stock 700r4(good stock trans when it came out). also have all the stock a/c stuff to put back on it desired. like I said anything I have syclone related will go with the truck sale.
gringo76
Re: syclone f/s
Sounds like a solid build. Truck looks great, how are you controlling the 60e?
thanks,with a tci trans controller. pretty cool, you can tell the trans to do pretty much what ever you want it to do and control lock up. guess I should have mentioned that in add lol. to much stuff to remember
gringo76
Re: syclone f/s
all right about ready for this to be gone, got new project awaiting for attention. no more firm price, all offers welcome
