For those who care, I have some downpipe jigs setup for KB and stock/atr headers.
For KB headers I have a 3" mandrel bend 2 piece downpipe. It is connects with a v band clamp in the middle and does not leak. It is available in stainless or mild steel, and will clear ac with turbos up to 88mm. Plug change is a breeze.
For ATR/Stock headers I have a 3" downpipe mandrel bend 2 piece with v band clamp also. Stainless also available. Plugs are easy to change and it also works w/ or w/o AC(We have two versions). We use the PTE housing for best seal and turbo placement, and machine it to work properly with an
external wastegate. This is the preferred setup to use if you are running high flowing big shaft turbos. This setup is like the ATR one, but we use 1.75" wg tubing, and machine the wg port another .5" over the standard pte size, plus you eliminate the 3-4 bolt adaptor which WILL leak. Expect rock solid boost control!
If you want internal wastegate, the pte is the way to go.
A one piece downpipe in 3" would be impossible to install/remove, and E-Rue there is no point to having a 3.5" downpipe if you are going to neck it down at the cat or muffler. It must stay the same or get larger.
